SOURCE: need to clean carburetor of troy built trimmer.
Go to any auto parts store and buy an aerosol can of carbeurator cleaner. Remove the air cleaner filter and give the air intake a couple of squirts. Pull the cord and turn the engine over a couple of times to draw the cleaner into the carb. Then let it sit for an hour and dissolve what ever is gumming up your carb.
SOURCE: have a troy built TB575SS trimer. Pull cord has
The starter recoil spring may have possibly broke or the rope is hung up somewhere on or in the pulley. A lot of these units are assembled using Torx (Star) head screws and disassembly requires a couple different sizes to accomplish. Take your time...you will see the screw heads, but reloading a starter spring for a trimmer is a little tricky and you may need help doing so, but you can fix this yourself.
