Thread appears to have gotten caught inside between upper thread guides 2 and 3. How do I open the left side of the machine to disentangle the thread?
SOURCE: Thread getting caught underneath
you need to replace your shukle that holds the tread bobbing below.it is either slack or broken . if it is slack then you tighten the little screw that holds a cover that gives the thread tension .if its broken then replace it.once the thread is slack below it will cause your thread to bundle up.
SOURCE: Threading my sewing machine
Go to http://www.singerco.com/accessories/manuals.html And type the model number in the manual search. Reading your message again, it might be that you have already downloaded the free one. Sorry if this is case. There is however a generic threading guide here http://www.singerco.com/resources/threading.html Hope this helps a little! Regards
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
SOURCE: NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Make sure you are threading the machine correctly and it has the proper tension. Also check the bobbin the thread has to go thru the little lash
SOURCE: WHERE CAN I FIND MANUALS FOR JANOME SEWING
Look HERE for Janome User Manuals, enter model number in the search box (top left). Janome Service & Repair Manuals HERE just request your model.
