Question about Jason Natural Cosmetics Jason Forma 72x36x22 Oval Combo Air-Whirlpool Tub - AC630
Refrigerator still not cooling the back of refrigerator is solid and mice can't get in is there something else that could be wrong turn of refrig for about an hour the freezer is cool but refrig lost about 5 degrees fast
    Problem Solver:
  • 17 Answers
Put all your food in the freezer. You'll have yourself a redneck refridgerator but, hey, whatever keeps the beer cold. Git er done.
Posted on Aug 10, 2009
SOURCE:
I reinstalled my electric water heater after replacing a floor. That was four hours ago. Still no hot water and I hear water running like a washer is filling. What's wrong?
If you failed to turn off the breaker before you emptied the tank then the element had no water to cool it. It would have blown a hole in it. If it is ok by some miracle then try turning off the breaker and turning it on again. As for the sound it would only do that if there was a large vapour lock.
Nov 23, 2013 | RTO Atwood DSI-RV Water Heater-6 Gallon
Ice maker not working just changed the filter water works but ice maker not working
Check the plastic lever on the door. It usually moves closed when the door is shut to turn ice maker on. The lever can freeze and stop the ice maker.
Sep 23, 2013 | Whirlpool Gold GI6FARXXF 25.5 cu. ft....
Wiring schematic for a upper thermostat
Jan 2013
1) Copy following links for wiring upper thermostat:
http://waterheatertimer.org/images/WH-w-combined2-1000.jpg
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
2) Thermostat must sit flat against tank wall to read correct temperature, and entire opening must be covered with insulation so cool room temperature will not interfere with temperature reading.
Be sure to put cover back on side of tank for electrical safety, and to prevent any possible fire caused by melted parts and overheating.
3) Tighten wires very tight under screw plate, and make sure only copper wire is used, and all wires under plate are same gauge, do not mix stranded wire and solid wire or stranded will become loose.
Only copper under the screw plate and cut back insulation so no insulation gets under screw plate.
http://waterheatertimer.org/images/Burned-thermostat5-143.jpg
4) Add comment and say what you are doing
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 23, 2013 | Rheem Water Heaters
I need to suppress the back voltage supplying my gas fired boiler
Have you thought about putting a diode in the input line ? or something similar never heard of this problem before and i would suggest that you consult a full time installer as they will have encounted this before and know what to do ,forget the diode thing i would expect that the wiring is wrong somehow and the supply is permant to the heater and the switch completes the circuit where i think the power shold go to the switch first then the thermostat and from their into the heater ignition system and yoyurs isnt in this order
Dec 26, 2011 | Water Heaters
Rheem tankless shuts down on it's own.
Check to make sure wire is solid copper thermostat wire and not stranded
Aug 15, 2009 | Rheem Tankless Hot Water Heater...
Rheem powervent ignites then goes out, electronic ignition.
Sounds like a bad thermocouple. This part sends a millivolt signal to keep the gas valve open but shuts it off when it cools - or if something goes wrong with the ignighter - to prevent fires. It's easy to replace and not super expensive. See your local Rheem dealer.
Aug 13, 2009 | Water Heaters
Whirlpool Refrigerator/Freezer not cooling
Unplug from wall and let unit subside 1 hour. then plug back in and check operation. Was unit tilted or moved prior??
Please rate. Thank you. jj505
Mar 28, 2009 | Jason Natural Cosmetics Jason Forma...
Water heater ground
You have clearly lost your ground due to PVC. One solution would be to run copper ground wire from the hot water tank to the metal splice on each end of the PVC. It is not necessary to go all the way back to the breaker box.
Jan 23, 2009 | Water Heaters
Jason Natural Cosmetics Jason Forma 72x36x22 Oval Combo Air-Whirlpool Tub - AC630 Logo
64 people viewed this question
Top Jason Natural Cosmetics Water Heaters Experts
Donni Steen
Paul Carew
Are you a Jason Natural Cosmetics Water Heater Expert? Answer questions, earn points and help others
