Nickel-metal-hydride is less forgiving than nickel-cadmium, if
applied in high and low temperatures. Nickel-metal hydride may not be
quick to load below 10 â° C (45 â° F) and can not be slow to load below 0
â° C (32 â° F). Some industrial chargers are designed to adjust the
rate to the current temperatures. price sensitivity does not allow the
processing temperature sensing charger consumers.
At higher temperatures, the charge acceptance of nickel-based
BTP-58A1 batteries is drastically reduced. A
HP 530 battery that
provides up to 100% when applied at moderate temperature can only accept
70% if charged at 45 â° C (113 â° F) and 45% if charged at 60 â° C (140
â° F). This demonstrates the poor performance of some summer car
charger.
Lead-acid is fairly tolerant to extreme temperatures, as we are
familiar with our car batteries. Part of this tolerance is accredited to
the slowness of the system lead-acid. Some brands
Inspiron
Mini 9 (all 8.9 series) battery can freeze and low loads, while
others say the damage and provide reduced service and a short life.
To improve the performance of lead-acid battery to colder
temperatures and avoid thermal runaway during periods of heat, the
control voltage limit, at which the
INSPIRON 9300
battery is charged, is important. Implementation of this measure can
extend the battery life of up to 15%. General guidelines suggest a
compensation of approximately 3 mV per cell per degree Celsius. The
voltage regulation has a negative coefficient, meaning that the
threshold voltage decreases with increasing temperature.
Heat kills
DV2000
battery. The hotter the cells, the shorter the life. High
temperatures can not always be avoided, especially during fast charging,
but efforts must be made to keep this short time. While 45 â° C (113 â°
F) is acceptable if kept short, at 50 â° C (122 â° F) and above, the
battery starts to suffer. Note that the cells inside the packaging are
always a few degrees warmer than the temperature of the body.
