Model - Philips DSP1005 Sound Bar
SOURCE: i need codes for philips universal remote control
http://www.lexrixa.com/vcr%20codes.pdf
Some kind soul scanned the code book.
lost manual tring to hook up dvd/vcr emerson up need code
SOURCE: philips universal remote codes for symphonics tv
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.
Press the Channel Up button repeatedly (up to 300 times) until the
device could be controlled changes channel. The red indicator blinks,
then stays lit. If you accidentally overshoot the code required, press
the Channel Down button to backtrack through the library until the
device changes channel. Pressing Channel Up changes direction to
forward again. Press and release the Mute button to install the code.
Hope this helps :)
SOURCE: Codes for my Philips universal tv remote control
I have the remote control but i need the code to add in my toshiba tv
SOURCE: codes for Philips 4 Device Universal Remote, Model US2-PM435S
Try this:
turn on the tv manually,then push and hold CODE SEARCH button until the red light stand still now release the button push and release the device button TV after that you got to push and release the ON/OFF button until the tv goes off stop.Now push the enter button to memorize the code check if the tv turn on with the remote.
You have to get some patience because you need to push the power button between 1 to 110 times.Good luck
