Question about HEWLETT-PACKARD HP 2140 Fax
Off and on button on hp 2140 fax - HEWLETT-PACKARD HP 2140 Fax
2 Suggested Answers
SOURCE:
  • 102366 Answers
SOURCE: I need fax setup for Hp 2140 Fax or a manual
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=3819105&lc=en&cc=us&dlc=en&lang=en&cc=us
Posted on Dec 06, 2010
FAX MACHINE 2140, THE PAPER FEED WILL NOT CATCH CAN THIS BE FIXED
it can.there is,inside paper feed section, some rubbers(one or two) try to clean them with alcohol and cloth,gently!
Feb 26, 2015 | HP Fax 2140 - fax / copier B/W
How can I fix paper feed problems for hp 2140 fax
Clean the roller and separation pad in the paper pick up area. Use a rag w/ soap(just a little w/ hot water or use SANDED PAPER and gently do circular move to GIVETHE RUBBERA STRONGGER GRIP or replace it.
Jun 25, 2014 | HEWLETT-PACKARD HP 2140 Fax
Receive a fax
hi , please following the step , fax ring the time you take hand set & press the start button & place the hand set
Mar 24, 2014 | HP 2140 Plain Paper Fax/copier W/ink brand...
Hp fax 2140 sends but does not receive faxes
check if the LINE is connected in the RIGHT JACK (LINE), not in the TEL jack. Check the panel or display if it is in (FAX OR AUTO) if the mod is in TEL it won't receive.
Dec 10, 2013 | HEWLETT-PACKARD HP 2140 Fax
How can I set up my answering machine with my hp 2140 fax
Use the fax setup wizard from the HP toolbox , when it asks if you have an answering machine connected to the fax line say yes. Or setup a distinctive ring from you phone company and set the fax machine to answer double rings only. Use fax setup wizard to do this as well.
Jun 14, 2011 | HEWLETT-PACKARD HP 2140 Fax
Our HP 2140 fax under distinctive ring setting DRPD was answering under our Master ring (double Ring) until yesterday it switched inside somehow where it now answers regular phone ring instead of...
Was the fax plugged into another telephone line? Maybe a power surge?
My solution would be to reconfigure the fax from scratch to learn the ring pattern.
From the Manual:
Step 1-Teach the HP Fax the ring pattern
The HP Fax will learn the ring pattern when you call it from another telephone or fax
machine.
1. Be ready to call the fax machine.
2. Press Menu repeatedly until BASIC FAX displays and press OK.
3. Use LEFT ARROW - RIGHT ARROW BUTTONS to scroll through the options until DRPD Mode displays and press OK.
Call this fax from another fax machine... Waiting Ring...
will display.
4. Call the HP Fax.
DRPD OK will display when the pattern has been learned and the HP Fax will return
to Ready mode.
Step 2-Set up distinctive ring (DRPD) answer mode
Once you have activated distinctive ring, it becomes one of the answering modes you
can select by pressing the Mode/Contrast button.
Press Mode/Contrast repeatedly until DRPD Mode appears in the display.
• In Ready mode, DRPD appears in the right hand corner of the display.
• Now, the HP Fax will manage calls and faxes as if it were set to AUTO mode
(AUTO mode on page 28)
TIP: Distinctive ring must be set up again if you reassign your fax number
or connect the machine to another telephone line. Once set up again (that
is, the fax machine has learned the ring pattern and the answering mode is
correctly set), you should test the fax machine by calling the fax number
and another number on the same line. The machine should respond
appropriately to a call placed to the fax number with fax tones, and to a
normal telephone call with the expected ring pattern.
Mar 04, 2011 | HEWLETT-PACKARD HP 2140 Fax
Jul 24, 2010 | HEWLETT-PACKARD HP 2140 Fax
HEWLETT-PACKARD HP 2140 Fax Logo
50 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
elig1000
laulund
Level 1 Expert
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
