Question about HEWLETT-PACKARD HP 2140 Fax
I have a hp 2140 fax, showing a message to insert ink cartridge i have done don and still showing the same and not receiving any faxes
SOURCE:
  • 102366 Answers
SOURCE: I need fax setup for Hp 2140 Fax or a manual
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=3819105&lc=en&cc=us&dlc=en&lang=en&cc=us
Posted on Dec 06, 2010
  • 6 Answers
SOURCE: i have lost my manual
You can find instructions here on page 39.
http://static.highspeedbackbone.net/pdf/HP-2140-FAX-Machine-Manual.pdf
Thanks -Sa_Les_Ski
Posted on Feb 28, 2011
SOURCE: My 2140 HP Fax will
you might need to update your driver, which you can do at the following site.
http://www.driversquad.com/driver.php?option=o&prodid=172&cust=HP+USB+download_AD_search.swagbucks.com_1&channel=&subid=201_US*DR_o&roia=!iicYvq1BAAKLOkMAAAYOVQAAZT5CAABnCA-A
or if all else fails, re-install your software, which you can also do through HP's website
  • 51 Answers
SOURCE: Hello, We can receive faxes but
You have to go into the settings on the fax machine. There will be an option for a prefix number. Someone put a 9 in there. Having the 9 in there will make it dial a 9 then the number you are trying to faxt too. Remove the 9.
Posted on Mar 03, 2011
  • 55 Answers
SOURCE: Our HP 2140 fax under distinctive ring setting
Was the fax plugged into another telephone line? Maybe a power surge?
My solution would be to reconfigure the fax from scratch to learn the ring pattern.
From the Manual:
Step 1-Teach the HP Fax the ring pattern
The HP Fax will learn the ring pattern when you call it from another telephone or fax
machine.
1. Be ready to call the fax machine.
2. Press Menu repeatedly until BASIC FAX displays and press OK.
3. Use LEFT ARROW - RIGHT ARROW BUTTONS to scroll through the options until DRPD Mode displays and press OK.
Call this fax from another fax machine... Waiting Ring...
will display.
4. Call the HP Fax.
DRPD OK will display when the pattern has been learned and the HP Fax will return
to Ready mode.
Step 2-Set up distinctive ring (DRPD) answer mode
Once you have activated distinctive ring, it becomes one of the answering modes you
can select by pressing the Mode/Contrast button.
Press Mode/Contrast repeatedly until DRPD Mode appears in the display.
• In Ready mode, DRPD appears in the right hand corner of the display.
• Now, the HP Fax will manage calls and faxes as if it were set to AUTO mode
(AUTO mode on page 28)
TIP: Distinctive ring must be set up again if you reassign your fax number
or connect the machine to another telephone line. Once set up again (that
is, the fax machine has learned the ring pattern and the answering mode is
correctly set), you should test the fax machine by calling the fax number
and another number on the same line. The machine should respond
appropriately to a call placed to the fax number with fax tones, and to a
normal telephone call with the expected ring pattern.
Posted on Mar 05, 2011
Change Ink Cartridge message won't disappear from screen even after I changed the cartidge.
Make sure you did put in a genuine and new cartridge. Then you have to make sure the contacts on the chip that is on the cartridge are clem and shiny. Not a spec of dust is allowed on the contacts. After replacement switch of the printer and switch on, to make sure the printer gets a reset and will start up with a complete check of the printer.
Jun 23, 2014 | HEWLETT-PACKARD HP 2140 Fax
Receive a fax
hi , please following the step , fax ring the time you take hand set & press the start button & place the hand set
Mar 24, 2014 | HP 2140 Plain Paper Fax/copier W/ink brand...
Install ink cartridge after the installation
INK CARTRIDGES ARE TIME SENSITIVE, check if the date in the box was current or expired.
Nov 19, 2013 | HEWLETT-PACKARD HP 2140 Fax
I have an HP 2140 fax purchased one year ago. I have never replaced the catridge and have used the fax about once a month. Today I am trying to copy and it won't print. I cleaned the nozzle and still...
New cartridge wouldnt print but sounded like it was printing. You can check ink levels clean or align cartridge by pushing menu then tools. I cleaned contact points w qtip and alcohol. What seemed to work is putting alcohol on cartridge where ink is released and putting back into machine wet did this three times first time little dots of ink then a faint print and now it is printing must have been dried ink further then I could access.
Apr 12, 2011 | HEWLETT-PACKARD HP 2140 Fax
I have lexmark x7170 all in one printer and i can't receive faxes it says memory full but when i try clearing it it says no pending faxes so i cam't. What can i do?
This temporary storage of fax may happen when one of your cartridge is detected low ink level. Try to replace your low ink cartridge. Sadly, if you have navigated away from the fax menu after inserting a new cartridge or clearing the message, you may lose the fax. You can try to have the sender resend the message. When this problem happens again, just replace your cartridge without turning off your printer. Once inserted, accept the incoming fax message to print it.
Feb 16, 2011 | Lexmark X7170 All-In-One InkJet Printer
We purchased a new cartridge because it said install new ink cartridge,we installed new cartridge it still says install new ink cartridge and will not receive or send faxes
it will not send or receive a fax if the error is still there. Clear the error by trying these steps:
-open cartridge door and remove the cartridge
-unplug the power cord at the back of printer
-after 30 seconds, plug the cord and turn on the printer. It will ask for the cartridge.
-Open the cartridge door and insert the cartridge
-close the access door
-if the error is cleared, try faxing again.
I hope this helps.
Regards,
Mar 02, 2009 | HP 640 Inkjet Fax Machine
Message: Intall new ink cartridge. Ink Low
When you hear the fax ringing, press the start button. It sounds like you are not set to AUTO RECEIVE
Jan 20, 2009 | HP 1040 Plain Paper Inkjet Fax
Replaced Ink Cartridge
turn fax machine off open cover and put 3 drops of 3 in 1 oil on the the big silver bar the ink cartridges ride along perform alignment and try to recieve fax if this doesnt work clean all the rubber feed rollers with isopropanol alcohol (rubbing alcohol) applied to a microfiber towel then try.
Jan 15, 2008 | HP 1220 Plain Paper Inkjet Fax
HEWLETT-PACKARD HP 2140 Fax Logo
131 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
elig1000
laulund
Level 1 Expert
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
