Have you switched ON its main power switch at control panel of the TV? Without turning it ON, you can't turn the power ON by it remote control.
Do the standby LED at the front of the panel lights up. If not check whether the switch I've pointed out here is ON. If the switch is ON and the power LED at the front panel do not light up, the fault is with its main power regulator board, inside. If so check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
