Manually turn the motor and drum and listen for the
noise, if so the motor bearings, the drum agitator shaft and fittings must be
checked. Also the suspensions which include the shock absorbers and springs,
the body clamps must be checked to be in correct alignment and not changed in
position. Tightening of the mounting is
also very important. Finally in most cases a drop of OIL or smear of grease on
the moving parts cane solve most issues.
Check this link :
Hi Philip McDivitt, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? what is the issue? there is no tightening. if it appears loose, then most likely you need to replace the rollers that it spins on. four of them.
