While formatting i receive the msg write protect and windows cannot format the drive...
My 4gb memory card SD showing 30.1mb and can't formatted it{Transcend}
Have you checked the little sliding lug on the memory card (or it's larger carrier card) is not set to "Locked" or "Write protected"?
Kevin
Hello.
Check the lock pin on the MicroSD
Try to format the card using HP Format Tool
Hope it helps.
SOURCE: MY FLASH SHOW ME THIS MESSAGE THE DISK DRIVE IS NOT FORMATED DO YOU WANT TO FORMATE IT NOW
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
then you restore it to its default status
Right click on your drive select properties then on customize restore Default in W 7
If you need more help with this post a reply
hope this helps
