Question about Hisense 50 Class 1080p LED Smart HDTV - 1920 x 1080, 120Hz, 2000000:1 Dynamic, 4x HDMI, Built-in Wi-Fi 50K610GW-RB - 50K610GW-RB
Cannot connect to my wireless network
I Receive a connection failure "time out" message when I try to connect to my wireless network.
  • Hisense Master
  • 10,543 Answers
Recheck your router to see if the mac address of the TV is listed on the wifi setup page. On the TV, make sure the router password is entered correctly
Posted on Jul 23, 2016
SOURCE:
Xbox 360 wireless adapter doesnt work the light on the back just stays red and i dont get how to make it work
Hi. You just need to configure your adapter. It is not broken, it just needs to be set up properly. For information on how to do this, please see: http://support.microsoft.com/kb/908877
Feb 28, 2011 | Microsoft Wireless Network Adapter Xbox...
Acer 5100 wireless connection
may be the connection you are trying to establish must have their server down....
Mar 04, 2008 | Acer Aspire 5100 Notebook
I have an ac adapter for the new xox 360 250 gb , that has the red light lighted up that means false alarm what should i do to get it back to green its been 1 week?
Check the status light on your adapter The state of the adapter's status light indicator can tell you the status of the Xbox 360 Wireless G Networking Adapter. Here's what the different lights mean:
  • Steady green light: The adapter is connected to a wireless router, gateway, or access point. The adapter is ready to use.
  • Steady red light: The adapter is ready to be configured. For information on how to do this, please see: 908877 (http://support.microsoft.com/kb/908877/ ) How to configure wireless settings on your Xbox 360 console
  • Flashing red light: There is a problem. The adapter might be experiencing a hardware failure. Contact Xbox support.
  • Not illuminated: The adapter is not receiving power. Unplug the USB connector and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.
  1. On the console, go to My Xbox, and then select System Settings.
  2. Select Network Settings.
  3. Select Configure Network.
  4. On the Basic Settings tab, select Wireless Mode.
    Note If wireless mode is not available and you are using the black Wireless N Networking Adapter, try using the software installation disc included with the adapter. For more information about how to do this, please see the following article:
    977641 (http://support.microsoft.com/kb/977641/ ) How to set up the Xbox 360 Wireless N Networking Adapter
  5. Select Scan for Networks.
  6. Select your wireless network name.
    If your network is not listed, try the following:
    1. Select Specify Unlisted Network, and enter your wireless network name (also referred to as your Service Set Identifier [SSID]).
    2. Select your wireless security: WEP, WPA, WPA2, or No Security (if your network doesn't have a password).
      If you can't connect to your wireless network, try improving your wireless signal using the tips in the following article:
      909336 (http://support.microsoft.com/kb/909336/ ) Your Xbox 360 console receives a weak wireless signal
  7. Enter your wireless network password, and then select Done.
    Note Make sure that you have entered the correct password. An incorrect password might allow your console to connect to your wireless network, but you might receive an IP address error when you test your Xbox LIVE connection.
  8. Press B on your controller, and then select Test Xbox LIVE Connection.
    If you successfully connect to Xbox LIVE, you'll see this screen:
    If you receive an error message, please go to www.xbox.com/networkhelp (http://www.xbox.com/networkhelp) for further help.
Dec 03, 2010 | Microsoft Wireless Network Adapter Xbox...
Unable to use the wireless setup wizard - I am trying to connect my pc with my wireless printer. When I try to use the setup wizard on the pc it says depending on the wireless software installed on this pc...
The Wireless Network Setup Wizard and the View Available Wireless Networks feature both rely on the Wireless Zero Configuration service to provide their functionality to Microsoft Windows XP Service Pack 2 (SP2) and Microsoft Windows XP Table PC Edition 2005. If the Wireless Zero Configuration service is not available, you receive an error message that directs you to this article. This behavior occurs for several reasons. Some computer and hardware manufacturers provide their own configuration software that replaces the Wireless Zero Configuration service that is provided in Windows. In that case, you must use the software that is provided by the manufacturer to configure your wireless network. If you want to use the Wireless Network Setup Wizard or the View Available Wireless Networks feature to configure your wireless device, see the documentation that came with your computer or with your wireless network card. Use this documentation to determine whether you can use the Wireless Zero Configuration service to configure your wireless network. Sometimes, you cannot use the Windows functionality.
If your computer or your wireless network adapter did not come with its own wireless network software, follow these steps:
  1. Click Start, click Run, type ncpa.cpl, and then click OK.
  2. Click Network Connections.
  3. In Network Connections, click to select your wireless connection, and then clickChange settings of this connection.
  4. On the Wireless Networks tab, click to select the Use Windows to configure my wireless network settings check box.
To start the Wireless Zero Configuration service, follow these steps:
  1. Click Start, click Run, type %SystemRoot%\system32\services.msc /s, and then click OK.
  2. Double-click Wireless Zero Configuration.
  3. In the Startup type list, click Automatic, and then click Apply.
  4. In the Service status area, click Start, and then click OK.
If you receive an error message when you try to start the service, see the "References" section for more troubleshooting information.For more information, click the following article numbers to view the articles in the Microsoft Knowledge Base: 815485 Overview of the Wi-Fi Protected Access (WPA) security update in Windows XP 313242 How to troubleshoot wireless network connections in Windows XP
Feb 26, 2010 | Acer Aspire One PC Notebook
How do i turn on the wireless function on my router
If you are trying to connect to the wireless network, then first you should know all the wireless settings of the router ( SSID , Security key or password).
If you don't the wireless settings of the router , then you will need to access the router set up interface.
On the set up page of the router you will be able to find the wireless settings of the router.
Once you have the wireless settings of the router then you just need to connect to the wireless network on your computer.
For Windows XP -
In case of windows XP computer you will find the wireless network connection Icon In the bottom right hand corner. right click on it and go to the option " View available networks ". You will be able to see your wireless network. If you do not seethe icon there , then try START ==> Control panel==> network connection. You will find the wireless network connection option.right click and go to " View available networks ".
If you get the message " Windows can not configure this wireless network " , then there is another software utility on your computer which is managing your wireless network. You will need to use that utility to connect to the wireless network. Suppose you have Linksys adapter on your computer , then there must be Linksys utility on your computer which can connect you to the wireless network. if you are not able to connect using that utility then you can switch over to the Windows Utility.
If you get the message " NO wireless networks are found in the range " , Make sure that the wireless switch on your laptop is turned ON. On the laptops there might be a wireless Switch that you will need to turn on. On Some laptops the wireless switch may be the combination of Fn + F2 Or Fn + F5 Or may be different than that. Once you turn on the wireless switch you will be able to connect to the network.
If you seethe wireless network and you tried to connect to the wireless network , some times you will get the message " Waiting for the network to be ready ". That means you might have tried to connect to this network before with different wireless settings . In this case you will need to remove the network from the preferred networks and try to connect again.
WINDOWS VISTA/ Windows 7
In case of windows You will find 2 computer icon in the bottom right hand corner.Right click on it and go to the option " Network and Sharing center ". Once you open the network and sharing center you will find the option " connect to the network " in the top left hand side. Click On connect to the network and you will see the wireless network that you want to connect. If it secured network then type the network key or passphrase and you will be able to connect.
If you get the message " additional log on information required " then you will need to add the wireless network manually.
If you get the message " settings saved on this computer do not match ..." then you will need to remove the network from the preferred network list. Try to connect again.
If you get the message " Press the configuration button ..." , On the same window at the bottom you will find the option " I want to enter the key manually " or " I don't want to configure the network ..." Click On it and it will ask you for the key.
If you see " Enter PIN number " , then at the bottom you will find the option " I want to enter the key manually " or " I don't want to configure the network ..." Click On it and it will ask you for the key.
For MAC OS
In case of MAC OS, you will find the AIRPORT icon the right hand top corner. If you click On it, it will try to connect to the wireless network. If you network is secured then it will ask you for the wireless network key or password. type the key and it will connect you to the network.
If you get the message " error joining the network " and if the wireless security type is WEP, then try to connect to the wireless network again. It will ask you for the network key / password again. Now this time enter $ sign before entering the network key . It will connect you.
Click Here for more info
Dec 22, 2009 | 2wire 2700HG-B Router (2700HGB)
How do you set up the wireless
For Windows XP -
For MAC OS
Dec 19, 2009 | NetGear WGR614 54Mbps Wireless Router...
My wireless connection no longer works.
go to the DOS prompt and type ping 127.0.0.1 if you receive packets then your card is ok. If your card is ok then go into control panel>network connections>new connection and follow the wizard
Rate 4 diamonds
Mar 02, 2009 | Compaq Computers & Internet
MySQL can't connect Error
Guess you are referring to this error message -
Check your username & password, and make sure that you are authorized to access the server.
If your password & username are correct, there might be a network problem that prevents you from connecting to the machine where the MySQL server is running. To make sure that they are no network failures, click on the "ping" button.
This will "Ping" the MySQL server host. If the host is available (no network failure), you will
receive a message similar to this -
Reply from 127.0.0.1: Time=0ms TTL=128
Reply from 127.0.0.1: Time=1ms TTL=128
If you don't it means there's a problem with the network.
Jul 27, 2008 | Sun MySQL
'Windows Cannot Connect' Error message
Are you sure your computer is compatible for the wireless, and does it have the necessary drivers?
Apr 02, 2008 | Arris SURFboard SBG900 Wireless Router...
Palm wifi url connection
This can happen if the wireless network you're trying to connect to is password protected. If you can see the name of the Wi-Fi network you're trying to connect to and there is a padlock symbol next to the name then you'll have to enter the WEP or WPA-PSK security keys. If this is not the case and this is your home wireless system which is unprotected then I suspect what's going on is that you may need to enter a DNS server number for your network on the Palm. To do this, select a wi-fi network you're trying to connect to, click edit, choose "configure", click on "Details". Where it says "Connect to:" select "infrastructure" then click on the "Advanced..." buttton. Try putting in the DNS server number manually for your internet service provider.
Nov 02, 2007 | Palm TX Handheld
Hisense 50 Class 1080p LED Smart HDTV - 1920 x 1080, 120Hz, 2000000:1 Dynamic, 4x HDMI, Built-in Wi-Fi 50K610GW-RB - 50K610GW-RB Logo
212 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Paul
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
