A
Anonymous Posted on Jul 22, 2014
The device could not be locked. Check that another application isn't uing the device.
I get the message listed above.
1 Related Answer
CreativeTECH
Creative Tech
  • 1719 Answers
  • Posted on Dec 31, 2010
SOURCE: laptop not used for some years. could enter bios
I received an IBM laptop with same issue a few months back. The error message due to the drained out CMOS RTC (coin-cell battery), which retains and other BIOS settings.
The system is OK and all you have to do is to get the CMOS/RTC battery replaced by the a professional.
Good Luck!
CreativeTECH
Android tablet says connected but browser isn't working
Download opera mobile browser from the android market
3helpful
I have canon DR-2010C scanner which gives error after some times.my system is vista.the error is "The device could not be locked. Check to see that another application isn't using the device...
Question
canon DR-2010C scanner which gives error after some times.my system is vista.the error is "The device could not be locked. Check to see that another application isn't using the device -4630".
Answer :- change USB cable which is connect with scanner to PC or laptop definitely it will resolve.
By:- shyam [email protected] 9210845186
UNABLE TO READ OLD MESSAGES STORED IN THE SMARTPHONE IN THE PLAYBOOK.
On my playbook when I scroll down the list of email messages and get to a certain point it just downloads more older messages from the phone. If this isn't happening on your playbook, then you should try rebridging the devices. Go to the bluetooth connections screens on both the phone and the playbook and delete the other device from the device list. Then go to the BB bridge app and reconnect them. Hopefully that works.
2helpful
Laptop not used for some years. could enter bios OK to reset Replaced U/S CMOS battery with no problem. Restarted............ Message press F1 ibm bios setup press F11 to invoke IBM product recovery...
Good Luck!
CreativeTECH
Phone erases text messages and call log
This happens because of large applications are installed on the BlackBerry smartphone.
To resolve this issue, complete the following steps:-
  1. Make sure that the BlackBerry Device Software is installed on the computer to display the correct total application space.
  2. Determine the application space that is available on the BlackBerry smartphone by completing the following steps.
a) Connect the BlackBerry smartphone to the computer.
b) Open the BlackBerry Desktop Manager.
c) Double-click Application Loader.
d) At the Device Application Selection screen, under the application selection window, note the total application space.
NOTE:-Select the List additional applications that are installed on the connected device check box to include the applications that are installed outside of the BlackBerry Device Software applications and the file sizes.
3) Remove applications that are not required. For example, remove additional language packs and themes.
18helpful
6answers
How to change the message tone of htc touch P3452
go to my document folder of ur phone then my ringtones n just copy the tone u like in it n then go to settings > sounds n notification > notifications > then u will get ur tone in the check list of all the tones n select in event > new text message alret n then just done
Logitech QuickCam Communicate MP - black screen
  1. Either one of these image sizes:
    • Small image size: 160 x 120
    • Large image size: 320 x 240
  2. RGB, I420, or IYUV formats. (Each is fine; we recommend RGB 24.)
  3. Microsoft DirectX version 9.0
To get this information, click here to download a Microsoft application that checks to see if your webcam device meets these requirements.
To make it easy, when you’re asked where to Save the program, just save it on your Desktop.
Once it’s downloaded, here’s what to do:
  1. Double-click the amcap.exe file on your desktop.
    • If you have more than one webcam installed, click the Devices menu and select the one you want to use.
  2. Click the Options menu, then click “Video capture Pin.”
  3. Under “Color Space/Compression:”, choose one of the following formats:
    • RGB 24 (our recommendation)
    • I420
    • IYUV
    Note: If one of the options above isn’t in the list, then your webcam is not compatible with Yahoo!7 Messenger.
  4. Under “Output Size”, choose one of the following:
    • 160 x 120
    • 320 x 240
  5. Click OK
  6. Close the ampcap application.
  7. From your desktop, click ‘Start’ and select ‘Run’.
  8. In the run box, type: dxdiag
  9. In the confirmation dialog box, click OK.
  10. On the System Tab under ‘System Information’, look for DirectXversion. Verify that your version is DirectX 9.0. If it is, just click Exit. If your version is older than 9.0 (any lower number), click here to download the latest version of DirectX.
  11. Start the webcam from Messenger by clicking My Webcam in the Messenger menu.
Attention Logitech webcam users:
Some Logitech webcam drivers may cause one of the following problems:
  • Windows freezes when accessing the webcam
  • A black screen appears when using the webcam in Messenger
  • A ‘Webcam not found’ error message appears.
  • After 3 seconds, the sound drops out of calls made via Messenger
If you already verified that your device is compatible through the above steps and you’re a Logitech webcam user, please click here to update your Logitech webcam driver.
Logitech webcam won't work on windows live messenger
This could a problem of compatibility. Try to find if your web cam is compatible with windows live messenger for this you have to download from microsoft "amcap.exe". Run it and if you have more than one webcam installed, click the Devices menu and select the one you want to use.
o RGB 24 (recommend)
o I420
o IYUV
Note: If one of the options above isn’t in the list, then your webcam is not compatible.
o 160 x 120
o 320 x 240
5. Click OK
10. On the System Tab under ‘System Information’, look for DirectX version. Verify that your version is DirectX 9.0. If it is, just click Exit. If your version is older than 9.0 (any lower number), download the latest version of DirectX from Microsoft.
My LG S900 cam not working with messenger
Hi Rushguy55
It may be a Direct X issue.
First,
***Follow the link below to Test ur webcam using Internet explorer
http://help.yahoo.com/l/us/yahoo/messenger/messenger75/webcam/webcam-03.html
The above page will check compatibility with Y! messenger.
Minimum Requirements:
For your webcam to work with Yahoo! Messenger, it needs to support the following:
    • I420
    • IYUV
    Note: If one of the options above isn’t in the list, then your webcam is not compatible with Yahoo! Messenger.
    • 160 x 120
    • 320 x 240
  5. Click OK.
  7. From your desktop, click “Start” and select “Run”.
  10. On the System Tab under “System Information”, look for DirectX version. Verify that your version is DirectX 9.0. If it is, just click Exit. If your version is older than 9.0 (any lower number), click here to download the latest version of DirectX.
hope this helps. . .
djEnigma
9helpful
4answers
Aspire 5610-2762 Orbicam not working
** Note ** When the My Pictures or Pictures folder gets full, camera will not work - Cut and Paste all pictures in that folder to another folder and restart Orbicam program.
If that does not work then do this:
Start - Programs - look for Acer Empowering Technology then Acer E-Recovery - The look at the bottom and you will "Backup", "Burn disk" and Restore" choose Restore - choose Apps and Drivers at the bottom of Restore tab (it will say extracting) - once extracted - click Install - click Vista or (XP) on the left - click Drivers - click Camera or CCD - on the right side of the screen, click a phrase that has something like "Install now", follow on screen instructions.
old marine
old marine
ZJ Limited
ZJ Limited
