Panasonic Th-42px25u/p 42-inch High-definition Plasma Tv Logo
A
Anonymous Posted on Jul 22, 2014
What size are the screw holes for a Panasonic TH-37PX60U
I have a wall mount and the tv did not come with screws or even on the specs does not show the size screw to mount the tv
Level 3:
Top Expert:
  • Panasonic Master 76,851 Answers
  • Posted on Jul 23, 2014
Panasonic Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15007550
Points
237762
To know more, you have to download the service manual to this set.
3 Related Answers
Anonymous
  • 4889 Answers
  • Posted on Mar 01, 2009
SOURCE: no screws for the tv to mount to the bracket
You will 4 m5x18mm and 4 m5x25mm machine screws. That should do the trick..
Anonymous
  • 2992 Answers
SOURCE: What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
Anonymous
  • 14553 Answers
  • Posted on Oct 30, 2012
SOURCE: panasonic tc 32lx85 mounting screws sizes
Call Panasonic customer service and they will provide either the parts or the size and thread type----most of these bolts are common and can be purchased at Home depot etc.
What bolts/screws do i need for the holes at back of tv for wall mounting
The screws usually come with the mount. The size of the screws depend on the size and weight of the TV so there is no one answer.
CAN I GET SCREW HOLE SIZE OF BACK OF TV FOR WALL MOUNT
The 3 most common sizes for the bolts to mount the wall mount to the TV is either M8x20mm or M6x20mm or M4x20 depends on the size of the screen. This site has a chart that will show you what to look for, for your TV M6x20mm TV to Wall Mount Bracket Phillips Bolts Screws Stainless VESA 200
2answers
Size of wall mount for GPX LED HDTV
Not sure what you are asking. Are you looking for the screw for the attaching the mount to the TV or the mount to the wall.
If you are looking for the screw size for the back of the TV, it could be metric size M6 or M8. Just be careful of the length. Too long and you will ruin the TV. Maybe google the TV model and it might show in the owner manual the exact screw to use.
Panasonic tc 32lx85 mounting screws sizes
TH-C4HD18
the four holes on rear are for wall mounted bracket, the stand that goes in bottom generally requires the removing of a cover plate which will be about size of the upper part of stand and will be approx four screws, remove cover and stand will slot in and fix with scres/bolts accordingly.
Screw size for wall bracket
Hello. The best thing for you to do is take your bracket to a hardware store and get the largest diameter screw you can that will fit easily into the holes. Regarding length, you should try to screw into the wooden studs behind the sheetrock or plaster wall so you will want 2 and 1/2 or 3 inch screws. Be sure to drill a pilot hole for each screw but only go in half as deep as the screw is long and use a bit that is only half as big around as the screw is.
2answers
No screws for wall mounting 42 inch tv
any hardware store will have them bring your tv manual with you it will tell you the spec on the screw to connect to the 4 pre existing nuts on the back of the tv as far as from the mount to wall it will be a standard lag bolt small enough to fit threw the hole and long enough to go threw the drywall and about an inch and a half of the studd 2" to 2 1/2" inch lag bolt will work
1helpful
3answers
Tv didnt come with screws....
The size is #8-40 X 3/4". This is a specialty screw, so you're screwed
29helpful
3answers
4helpful
No screws for the tv to mount to the bracket
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
