Televison & Video Logo
A
Anonymous Posted on Jul 22, 2014
I have a60 inch hitachi projection tv. I tried to fix the screen alignment using the grid but the blue line doesnt move to line up on the grid. The green and red work fine. So theres a blue ghostly glow around the picture. How do I fix this?
gemagm
Level 3:
Master:
  • Master 689 Answers
  • Posted on Jul 24, 2014
gemagm
Master
Level 3:
Master:
Answers
689
Questions
0
Helped
119708
Points
1147
You will need convergence work done & for Hitachi I recommend a professional as the convergence will have to be reset for normal & HD pictures. See if you can get a quote from a local servicer.Be sure you are sitting down.
I really think your money would be better spent on a 21st century LED or LCD TV.
1 Related Answer
Anonymous
  • 4402 Answers
  • Posted on Dec 05, 2007
SOURCE: hitachi 52 projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
1helpful
Blue line convergence not working
<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">Projection <a href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target="_blank">TV</a> sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look <a href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target="_blank">3D</a>, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. <br /><br />This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem. <br /><br /><b>Common Symptoms include....</b><br /> <ul class="h_mi"> <li class="h_mi">Screen looks 3D <li class="h_mi">Colors don't line up <li class="h_mi">One or more colors can't be adjusted when using the convergence menu. <li class="h_mi">Screen is bowed or warped. <li class="h_mi">TV shuts off after powering on. Power light will blink. TV may also make a chirping noise. </li></ul>Here are some <a href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target="_blank">photos</a> of convergence problems.<br /><br /><img class="h_mi" src="/uploads/images/42D3683.jpg" /><br /><br /><img class="h_mi" src="/uploads/images/7859B01.jpg" /><br /><br /><img class="h_mi" src="/uploads/images/E87380C.jpg" /><br /><b>Here is a quick tes</b><b>t....</b><br /><br />Using your original remote go-to the settings menu then goto the convergence section.<br /><br />Try to adjust the red and then the blue convergence.<br /><br />You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight. <br /><br />If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem. <br /><br />Note: If you TV has as flash <a href="http://www.fixya.com/#" target="_blank">focus</a> or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix<br /><br /><b><img class="h_mi" src="/uploads/images/69189A5.png" />CONVERGENCE SOLUTION<br /><br /></b>You can see some more examples and find a fix using this link on Fixya <a href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull" target="_blank">http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull</a></span>
Lines, a little blurry, a little movement
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
I have a 57 inch rear projection t.v. the color looks 3d and the screen looks warped. the t.v is about 10 years old but i would like to fix it myself if i can. please help.
  • Screen looks 3D
I have a hitachi model 46f500 that looks distorted. (3d)
  • Screen looks 3D
Red and green lines, kind of 3D looking???
  • Screen looks 3D
Red, green, and blue lines at bottom of screen, mirror looking effect, also looks like 3D. Got at a garage sale so no manual.
  • Screen looks 3D
Convergence will not align The white grid lines used to align the red and blue is broken and wavey at the top left and lower portion of the screen
The convergence it dead,U know how to solder right?Buy the convergence kit,use what in that kit.Tries these websites.Tv Repair World.com,Ebay.com.
1helpful
Top of picture has distorted curve
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
I have a hitachi 50FX18B and the convergence lines...
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Hitachi projection tv
  • Screen looks 3D
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
