The volume on the radio is low when turned up all the way
SOURCE: Steering wheel buttons
Contact Crutchfield (contact info in the link) to see if this will work in your vehicle: http://www.crutchfield.com/S-FaQ8Wkvuw07/cgi-bin/ProdView.asp?search=steering+wheel&i=127SWIJACK
SOURCE: '02 monte carlo ss problems
if you give gaz its shake if you let go the gaz does it still shake if it still skake it probably wheel balance if it shake in the stering its the front if you feel it in our seat its the back but if it vibrate only when you give gaz it could be a cv joint or universel joint cheers
SOURCE: 2004 monte carlo sunroof won't close
THERE IS NO MAN OVERIDE, REMOVE THE DRIVE MOTROR AND THE SUNROOF WILL CLOSE.
SOURCE: radio locked, code needed
you have to call jbl and give them model and serial number may charge $25
