When I restart the torrent, after it does what my title stated, the service engine light comes on along with PRNDL1L4 and the T/C light goes off. It runs a bit better, then after a few trips to town the service engine light goes off and runs like normal. Here are the codes that it has thrown (read from a autozone code checker): 0705 0700 0700 Pd MIL ON I noticed that the times it has done said malfunction, that I have been on a incline or just coming off of one. And when it occurs, it's always shortly after starting the car. My model doesn't I have the T/C button. THANKS!!!!
SOURCE: How do you reset the check engine light on a
disconnect the battery for 5 minutes, this will reset the light, but if the problem that turned the light is no repaired the light will come on again in a few days.
SOURCE: 2006 pontiac torrent shut down car will just crank, not start
The factory alarm is not to be tampered with as you can reset it but not disconnect it as it's part of the main fuel injection system. Do you have the right key? Just because it turns and cranks doesn't mean it has the right code. the security light off with the key on ut not cranking? If it stays on you do have a security problem. The system can be reset ( if the battery is good, and hot. Trun the key to crank and letgo the security light will but on or blinking . Leave the key on till the light goes out (around 15 minutes. Once it's out turn the key off then back on and the security light will be back on again. again wait till it goes out turn off then on again till the light goes out. Now turn the key off wait a few seconds trun it on and crank the engine. If it starts then it's reset. Sometimes I've had to do this more than three times to get it to reconize the key as the right one. rember a store cut key won't ever work as it doesnt have the (brain in it the the factory key does. Lets say your wrong, about the security system. The fuel pumps go bad like crazy and its thier season to fail. They fail quicker if you $5 the car alot. (runing on empty) Was the check engine light on as it ran the last time it was running? If so the codes need to be retieved and repaired. A scanner will find the security enabled on too.
SOURCE: engine light was on... said running lean ...no
I appreciate the feedback and am somewhat better informed when I take the Torrent into the shop tomorrow...obviously a bandaid over the pig shaped engine light wasn't cutting it! The light came on within 10 miles.
SOURCE: hi i have a check engine light on,on my 2006 torrent
check all vacuum hoses for cracks especially at every conection there is
SOURCE: 2006 pontiac torrent dies while driving, comes up
U - CODES MEAN YOU HAVE TROUBLE IN THE VTD PASS LOCK COMMUNICATION.YOU COULD HAVE FAULT IN THE INSTRUMENT PANEL CLUSTER NO COMMUNICATION FROM MODULE.YOU COULD HAVE NO COMMUNICATION WITH BODY CONTROL MODULE OR NO COMMUNICATION WITH POWER CONTROL MODULE.
Testimonial: "Thanks for the info. I at least have something to go on now. "
The ignition switch
The Passlock?"¢ sensor
The BCM
The security indicator
The PCM
