Landice L8 80 LTD Executive Trainer Treadmill Logo
D
DEVON HALES Posted on Jul 22, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i fix an landice l8 trainer l5 error
Only the error pops up and it wont move or start up
Howard
Level 2:
Habit-Forming:
  • Expert 115 Answers
  • Posted on Oct 15, 2017
Howard
Expert
Level 2:
Habit-Forming:
Answers
115
Questions
Helped
97498
Points
237
That is a loss of speed error. you only get rid of it when the belt starts moving again
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
1 Related Answer
Anonymous
  • 79 Answers
  • Posted on Sep 14, 2010
SOURCE: landice L8 has an L5 error displayed wont start up
is a speed sensor problem or the card connectors are wired specifically where the motor wires, sometimes that part is too hot and breaks the solder
1helpful
Why does the display say L5
this a problem in 2 ways:
1) test the input voltage motor, if there are the motor need repair.
2) test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the block diagram atached.
Landice L8 automatically turns on by itself
It is either the control board or the overlay. I would think it is probably the start button on the overlay that is stuck. The solution is to replace the overlay.
1helpful
Landice L8 has an L5 error displayed wont start up
Landice L8 treadmill won't turn on
Check wall outlet for power , then if outlet is good unplug unit remove motor shroud you will see a charcoal or white ceramic fuse check it if open replace blows again immediately you have a shorted lower board. Here is the info Landice they help you with parts and get you in touch with a servicer if you need one.
Landice, Inc.
111 Canfield Avenue
Randolph, New Jersey USA 07869
(800) LANDICE
(973) 927-9010 - FAX: (973) 927-0630
[email protected]
Landice 8 over speed protection
first screen shows any error number? for what you describe I think it is simply speed sensor, try to check the cables leading to the sensor card. and then checks whether the sensor is aligned correctly.
Check speed sensor alignment.
It should be within 1/16" of the flywheel
and parallel to the flywheel.
Is it out of position?
I have a Landice L8 and the error code L5???
LS Error on Landice L-Series Treadmills with Belt Movement Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. This error can occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:A) Speed sensor is out of adjustment
B) Speed sensor is damaged or faulty
C) Display cable is damaged or faulty
D) Improper speed control wiring Corrective Action A) Speed sensor should sit parallel with the flywheel and gap between speed sensor and flywheel should be within 1/16". Adjust speed sensor if necessary.
B) Inspect speed sensor connector to relay board. Check for pushed pins or loose wires. Repair or replace speed sensor assembly if necessary.
C) Inspect upper harness or display cable connector to relay board. Check for pushed pins or loose wires, giving specific attention to pin 5 (brown) and pin 9 (green). Repair or replace display cable if necessary.
D) Inspect speed control wiring:
  1. Checking purple wire from V+ on pwm board to P3 on the relay board
  2. Checking orange wire from P1 on pwm board to P1 on the relay board
  3. Checking brown wire from P2 on pwm board to P2 on the relay board
  4. Confirm P3 on pmw board has no connection
Correct speed control wiring if necessary.
Details about LS Error on Landice Series Treadmills with Belt Movement
Landice treadmill 05 error code comes on when i hit start
Landice L8 Cardio trainer giving messages on readout P4 and L5
I've definitely never seen "P4" on a Landice before so I'm not entirely sure on that one. The other issues seem like they might be associated with stuck keys on the console. It's a very common problem if you have it in a humid area and/or it gets sweat on it during the work out. Being that it's a Landice, you should have a part warranty on it. Have you contacted them?
Top Landice Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Sportsmith LLC
Sportsmith LLC
ADMIN Andrew
ADMIN Andrew
Are you a Landice Exercise and Fitnes Expert? Answer questions, earn points and help others
