SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
SOURCE: Can't find the oil drain plug on Troy Bilt with 5.5 Honda engine
You may want to look under the deck. They sometimes put them there. And if it is a self propelled, you will probably need to remove or loosen the plastic cover that protects the self propelled belt.
You are looking for a nickel sized plug that has a square peg. Use an extension piece for a socket set if you don't have the proper plug removal tool.
Jim
SOURCE: troy bilt mower. starts but shuts off within seconds.
sounds like you have a primer bulb if you take the bolt that holds the float bowl off and take a tip cleaner that they use for welding tips and clean the holes out of the side and the top it should let the fuel in again that will save you a trip to a service repair shop
SOURCE: how do you tighten the control cable on a Troy Bilt mower?
Usually near the end of the cable there is a squeeze clamp on the side of the cable. Losen the mounting screw (DO NOT remove it) and slide the cable in the direction that will expose more cable. Tighten the mounting screw and test the control. It is really pretty simple.
Thanks for using FixYa.
Kelly
SOURCE: HOW DO YOU PUT A DRIVE BELT ON A TROY BILT 33"
I think you should go to your local dealer. They will be able to pull up the info you need and they may even print up for you a picture of the way the belt is installed. GOOD LUCK.
