Printer shows dev.home error....looked up the fix but the white cylinder does not turn whenn switched on..now hve a red light after a run nof one sequence of the led's...help !!
Please contact your local Xerox concessionaire. You will be better off with less down time.
Good luck.
SOURCE: printer Xerox Phaser 6110 -
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: A red light all the time on xerox phaser 6110.
I think I might know what this is. Mine did the same and I removed the waste toner cartridge (grey L shapped unit to the right of the colour cartridges under the front panel) I noticed it was quite full but a rocked it from side to side to settle the contents (be carefull as they can come out) and when refitted the light stayed off when powered up. I'm not sure if this waste cartridge needs to be replaced or you can simply tip it out into a bin, but I'll try that tomorrow when I can empty out side.
SOURCE: when the red light blinks
The blinking toner cartridge is low. Order a new toner cartridge. You can temporarily improve print quality by redistributing the toner. See "Redistributing Toner" on page 5.2 from the manual online as pdf: http://download.support.xerox.com/pub/docs/6110/userdocs/any-os/en/Guide_XP.pdf
