Re: Vauxhall Vectra GLS: 2LT: 16 Valve: Auto Estate: 1999 On the bottom edge of my front bumper: There's a rubber strip of about 3 to 4 inches (75/100mm) high, which has come adrift from the plastic edge of the bumper. It's ends are held in some plastic parts at each end of the main bumper, so its hanging down in the middle. So what holds this in place ? And what do I need to do to fix it ?
Due to the age of the vehicle and the fact that these type of situations usually happen due to physical damage. I would look to a pop riveter with backing washers and a good adhesive, Simply glue it in place, after cleaning both pieces with a solvent such as paint thinner, use tape to hold it in place and then drill it and pop rivet it using backing washers front and back at equal distances for further mechanical strength. Do both ends then the middle and then the middle of those open spaces that are left, depending on the width of the rubber strip you may have to do this again with the remaining undivided spaces.
