Logitech Headset Not Working with Windows 8 Mic is fine, just can't hear through the earpiece. Volume is turned up full
SOURCE: my logitech usb headset dnt work
your program is probably set to use the wrong input for the mic, check your settings.
SOURCE: my mic isnt working but i can hear out of my headset
If you are running Vista, make sure that you set your mic as the default. Then check on vent settings and make sure that your output setting are set for your head set. You can then test your headset inside of the settings tab.
SOURCE: Logitech USB Gaming Headset only working out of one ear
I've had this happen twice with Logitech headsets and believe it has to do with the cheap/fine wire they use in the cables. I suspect that a good tug on the cable will snap the wire or some other internal connection.
SOURCE: i cant get my computer to recognize my logitech
Your laptop has built in mic. This is why your mic is not work
SOURCE: Why won't my logitech headset work with windows 8?
Go to youtube to find http://www.youtube.com/watch?safe=active&v=KmzfJWVH6T8 go to start control panel then later go to mic or mirophone then later click or yes I agee then later let it download if cannot mean your sound is not load is put to 100% ok.
