Phone will not charge only vibrate. as of today will not charge used 3 different batteries and several chargers. It started earlier and would occasionally come on now wont and only vibrates
Could be a battery problem, ut is usually a problem with the charge cable or connector. Try a different charge cable, they are usually Micro USB connectors, and check if the power (MaH) Matches what your phone needs. Otherwise you might need to repair the port. Try this.
http://www.youtube.com/watch?v=q4e-5xkhvHA
SOURCE: samsung d900 vibrates when off
most times when mobile have water damage for a period of time, it is very hard for them to be working even after being service.
You both should take the phones to either a mobile tech or mobile service center and have them try to fully service the phones.
SOURCE: d900i
you phone sounds like a ws in water....but you mainboard is faulty....best to buy a new board or purchase a new phone....makes no sense getting it repaired the problem will still presist after awhile.
SOURCE: My Samsung Comeback will not
Hey! My Sister has the same problem. T-Mobile said that it is the battery. There was a defect with some phone batteries. You can buy the samsung battery from T-Mobile for like 48$ of go to cellphoneshop.net to get it cheaper. works great and is cheaper to replace than 48$ samsung battery!!
SOURCE: Need to reset samsung galaxy s2 phone. Can't
If you want to try a simple solution, Go to Settings, Wireless and Networks, then Turn on "Airplane Mode" wait until you see an airplane on the top status bar of your phone... then Turn OFF "Airplane mode"
If that doesn't work, and you want to reset your phone, take it to the place you bought it or any place that is on your carrier.
SOURCE: MY SAMSUNG GALAXY S2 WONT CHARGE
Try connecting your S2 with the usb cable provided to your desktop/laptop. If it starts recharging, then it is definitely your charger thats done for. Get a new charger...
