Chevrolet 1993 Chevrolet Blazer S10/jimmy S15 Radio Logo
A
Anonymous Posted on Jun 22, 2017
My 1993 4.3 blazer drove home now wont start put new plugs wire cap roter and pickup coil now it pops acupple times and than like flude tride using carb n choak and eather as well
Bought a blazer 3 owner thay said ran ruff and bad gass mileg i put battry and gass it fired up running ruff put coumpleet tune up in ran lots better nnext day no start found bad pickup n distrebitur put nw one in started right up went 4 a drile the further i got the wores it ran then died got started but would only run wide open had fun ride home but now wont start it pops a cupple times and smells fludded let site than same thang again and again
5 Related Answers
Anonymous
  • Posted on Jul 26, 2008
SOURCE: no spark on 1988 s-10
It could be that the ignition module is defective and causing this problem.If it's the original ignition module it may be time to replace it. The ignition module can be tested by your local Shucks or Auto Zone usually for free, The module when its starting to go out will work fine until it warms up, it will then quit working because the coils inside of it short out, until it cools down. If the module is completely gone there will be no spark at any time, The module is inside the distributor under the rotor held in by a couple of screws,
Anonymous
  • 217 Answers
  • Posted on Jan 17, 2009
SOURCE: 1998 Cavalier No Spark in cylinders 1 & 4
ignition mod. grounds,pcm or timing belt could all be it but, I would have to look at timing first.
Molson02536
Harvey N Tawatao
  • 3854 Answers
  • Posted on May 02, 2009
SOURCE: 91 chevy blazer 4.3 won't start after running.
Check the ECM for Codes to help you find out what's causing  the problem. Here is a simple and easy way to check.
On board diagnostic (OBD) was designed on vehicles equipped with electronic fuel injection so you can generally retrieve the codes yourself. No need buying a scanner or running to any parts stores to check the Check Engine. This system is called obd1 and applies to most vehicles made before 1995 for domestics and 1993 on imports. In this article, I will discuss the methods used by domestic vehicle manufacturers on how to check the engine lights in their cars and Trucks.
For GM domestic vehicles made before 1995, the diagnostic connector is located under the dash panel by the driver side. To get the check Engine codes to flash in your dash panel, use a jumper wire or a paper clip and connect terminals A and B of the diagnostic connector. Turn your ignition key on with engine off and the codes should start to blink. All codes should start with code 12 which is one long flash followed by 2 short flashes. This code 12 means the diagnostic system is normal and will repeat itself continuously if there are no trouble codes. Otherwise, code 12 will flash 3 times before flashing the fault codes.
Counting the codes being flashed is easiest way to trouble shot problems in domestic vehicles and most of the codes can be erased or cleared by disconnecting the battery negative terminal for 1 minute and reconnect. Just make sure to check your service manual in case you have electronic equipment such as radio or clock that needs reprogramming in which battery disconnection is not recommended. Finally after performing repairs on the culprit code, always go for a road test to confirm if the problem is fixed.
Here is a link with the GM codes. http://chevythunder.com/199295_lt1_trouble_codes.htm
Good luck and hope this helps
Anonymous
  • 30 Answers
  • Posted on Oct 14, 2009
SOURCE: 94 s10 blazer dies when put into gear
Sounds like a vacuam leak, best thing to use is cold start spray, by spraying the vacuam lines with this you will notice a change in the idle wherever the leak is at.
Anonymous
  • 75 Answers
  • Posted on Dec 05, 2009
SOURCE: i have 94 s10 blazer 4.3 the prob started the
throttle position sensor, or check to make sure you have vacume going to the map sensor. Alot of times the outlet on the throttle body gets plugged and there is no vacume at the map--causes it to die. unplug the throttle position sensor and then rev it up and see if its better.
1988 c4 Corvette no spark replaced icm distributor cap & roter i have 12v goining into the coil & the new coil test good new livewire plug wires still no spark ? any help would be appreciated thank's
Hello. It seems your Camaro has either a 'loose' timing chain and /or a faulty ignition module. I recommend having the ignition module tested first before moving to more complex process of elimination. Good luck and keep me informed; if you want to.
Car cranks but dont start
When the vehicle will not start when you spray water on the plug wires, that means that the insulation around the plug wires has failed. Replace the plug wires.
My cabrio wont start it will crank but not fire
When you squirt water on plug wires and the car stalls, that means that your plug wires are bad. PLUG WIRES (not rotor, cap, or any sensor).
Replace your spark plug wires with new, and you should be fine.
1994 plymouth grand voyager not fireing at coil also fuel pump not working drove home now won't start lady lost husband with 3 kids 1 grand kid needs help
No spark at the coil replace all spark plug wire and coil wire but start with fuel pump first it wont start anyways without fuel id look into a new cap and rotar with the plug wires might get lucky and find a distributor at a wreckers for the same price as cap and rotar
1helpful
I have 94 s10 blazer 4.3 the prob started the
1helpful
Wont start....2.8L 1987
Might want to check the timming belt..Does it even turn over when you try to start it?
2helpful
2answers
1993 blazer 4x4
I assume you have the 4.3 vortec. If so, check to make sure you have the spark plug wires in the right position on the distributor cap. firing order is 1,2,3,4,5,6. right side of engine is 1 front 3 middle and 5 rear. Left side of engine is 2 front, 4 middle, and 6 rear. On the distributor cap # 1 should be toward front of engine and work counter clockwise from there. Hope this is helpful. KS
1helpful
89 s10 blazer no spark
There is no test for module in distributor, but they often cause this kind of problem. Also while in there, check the pickup coil wires to make sure they are intact.
1993 S-10 Truck will not start
how about the coil have you tested it and DO you have a proper spark tester using a spark plug for testing the spark is no longer efficient! test the coil !!!
1996 Chevy Blazer Wont run
Replace the coil packs.....
Top Chevrolet Audio Players & Recorders Experts
Arnie Burke
Arnie Burke
Stan Ford
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
