SOURCE: Insignia Flat Screen TV - no cable signal
Hi, need some help here. I have a flat screen tv that will not go on. Its not even 2 years old. Yet I had to keep trying the wall outlet to get it to turn on. Now it won't go on at all. The tv light use to be blue when it was on. Now its pink? Should I ask santa for another, or can this be repaired without too much fuss/cost? Thanks!!!!
SOURCE: I need the remote control code(s) for my new insignia tv
10463 worked for me. Check out this site it should help:
http://www.insignia-products.com/universalcontrolcodes.aspx
SOURCE: insignia tv will not powerup
Nothing at all? Does the screen seem to go from dark black to a lighter shade of black?
If the screen appears to stay on the darker shade of black then it is broken, and needs to be sent for repair. ( ie the screen isnt powering on when the tv is and there is nothing you can do without opening it.
You might try unplugging all cables and leaving it off with no power for a day This is in effect performing a factory reset.
and this may sound stupid and patronizing but is the TV being taken out of standby mode and actually switched on?
Nick
SOURCE: Two questions: My Insignia NS-LTDVD 19 flat
This model/brand of LCDs does need a digital converter since they are a low end quality product, the manufacturers did not put an ASTC tuner to decode the HD signals.
The DVD assembly can be replace to fix the DVD issues.
I have a couple of these DVDs assemblies from a broken screens LCDs and they're like new condition.
Let me know if you need further assistance.
SOURCE: I accidentally tapped my Lcd insignia 32 inch flat
That 32" LCD panel will be more tahn this TV is worth, check with www.shopjimmy.com to see how much it goes for.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
