HTC EVO 4G Smartphone Logo
A
Anonymous Posted on Jul 21, 2014
Problem with my htc phone
I have had my phone for a couple years and it has quit ringing
dabade
Level 1:
New Friend:
  • Contributor 27 Answers
  • Posted on Jul 22, 2014
dabade
Contributor
Level 1:
New Friend:
Answers
27
Questions
0
Helped
7598
Points
29
Check volume settings, note that media and notification volumes are different.
Verify you haven't accidentally put it in silent mode. (On most phones that can be checked by holding the power button, and selecting the silent mode option).
Why can't I pull the ring up to unlock my phone
I would say your digitizer is going bad or has dead spot's. The digitizer's are quite cheap usually $9-15 but require a skilled technician for installation.
3answers
HTC touch phone crazy problem
Scan your mobile for Viruses. and check the setup for the line access
1helpful
My htc wildfire has no display however i can receive messages and calls (rings). It's just more than a year of use. This afternoon it just did not displayed anything as it is all black display. Kindly...
i would go with your first idea. if youve got good phone insurance why tinker when they can fix it no problem. if not i think the phone mightve taked a few to many bumps in its year of life
1helpful
I wanted to set the HTC snap phone to ring and vibrate at the same time but are unable to do so. Please advise. Thanks
In your profiles, hit Menu, then edit, then choose ring and vibrate. It might take a couple of tries because that is a known issue with the HTC Snap, Ozone and Sprint Hero. Reset your profiles to default and do this a few times. It gets a little tedious and annoying, but HTC hasn't fully addressed the issue yet.
2answers
Facing peculiar problme with my HTC Cruise Phone
Hi Nitin,
Select the network manually and try if other parties are able to reach you without any trouble.
1helpful
Battery on my HTC s710 lasts for 3-4 hours
if you momentarily push the "start" button, that should put the phone into hybernation. Which means the screen will go dark and quit using power. If the phone rings it will automatically wake up. If you want to use it just hit the start button again.
There are also some settings in the "settings" menu that determine when and for how long the screen stays illuminated when not in use.
1helpful
Phone doesn't ring, but other sounds fine
:) Sometimes happens to me also. I faced a similar problem before, I think one of the installed programs on your device does it, I couldn't remember the name of the application now but whenever I launch it, my phone sound goes to minimum, Just to let you know. Have a nice day.
2helpful
3answers
HTC Touch Pro only rings twice before switching to voicemail
I think the issue is a misconception on the operation of the phone. The phone flashes for the first ring, vibrates for the second ring, and then rings for the 3rd and 4th ring before dropping to voicemail. it requires a registry modification as can be found on some forums to make it "ring immediately." If you put the phone on vibrate it will buzz immediately and skip the flashing lights step.
5helpful
6answers
Phone doesn't ring for an incoming call
try installing this Hotfix
http://www.htc.com/us/SupportDownload.aspx?p_id=88&cat=0&dl_id=101
Hot fix for resolving ring tone and system sound loss problem in HTC Touch Date: 2008-08-28     CategoryHotfix
In some cases, there may not be any ring tone and system sounds on the HTC Touch when the device has not been soft reset after a few weeks of usage. Performing a soft reset will resolve this problem. You can also download this hot fix and install it on your device to prevent this problem from reoccurring.
It's a problem with your phone or the network. Take it back to the dealer and let them work it out.
Top HTC Cell Phones Experts
NOEL
NOEL
john h
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
