How do I remove the keyboard from Asus K50IJ ?
Try these steps:
1. Place your laptop on a clean, flat surface and remove all power sources from it. Open your laptop screen as far as you can.
2. Use the flathead screwdriver to pop open the hinge cover. Slowly and carefully pry it open from the right side to the left side, exposing the Asus keyboard screws. Using the Phillips screwdriver, remove the screws that hold the Asus K50IJ Keyboard in place. Keep these screws in a safe place.
3. Gently tug the Asus K50IJ Keyboard component toward your laptop screen. You are trying to pull it out of the slot that is located near the palm rest and mouse pad. It doesn't take much force, but you must be firm. Once you have pulled it out of the slot, you can lift it up and remove it from your laptop.
