Now
You do not need the software that comes with any modem:
Reset the router:
To restore the factory default configuration settings without knowing the administration password
or IP address, you must use the reset button on the rear panel of the router.
1. Press and hold the reset button until the Power LED turns red (about 6 seconds).
2. Release the reset button and wait for the router to reboot.
To log in to the modem router:
1. Type http://routerlogin.net or http://192.168.0.1 in the address field of an Internet browser.
Enter admin for the user name and password for the password, both in lower case letters.
NAT automatically assigns private IP addresses (10.1.1.x) to
LAN-connected devices.
? Enable. Usually NAT is enabled.
? Disable. This disables NAT, but leaves the firewall active.
Disable NAT only if you are sure that you do not require it.
When NAT is disabled, only standard routing is performed
by this router. Classical routing lets you directly manage the
IP addresses that the DG834G v4 uses. Classical routing
should be selected only by experienced users*
? Disable Firewall. This disables the firewall in addition to
disabling NAT. With the firewall disabled, the protections If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays! Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
