Question about Psi 2500 Mobile Pressure Washer 5hp Honda Engine
Starts but dies
Shoot it with eather will start then it will die
Trouble shooting briggs small engine carburators
TIME FOR A CLEANING AND REBUILD. CK FLOAT ADJUSTMENT AND FUEL LINE FOR CRACKS.
Sep 07, 2014 | Garden
Hi i have an 84 22r 4x4 that had the head gaskett and timing done about 3k ago and a tune up about 100miles ago and the other day it died on me as i was picking up speed in second and wouldn't start again...
If your backfiring most likely the timing is off. I would pull the cam cover and make sure all the timing marks are lining up when it is in Top Dead Center (TDC) Also on the older Toyota's there is a plug in the harness on the drivers side that has to be jumpered in order to set the timing correctly.
Jan 27, 2011 | 1984 Toyota Pickup Deluxe
My 1995 chrysler lebaron starts and dies. runs great on eather but wont squirt gas into the motor. fuel pump works great injectors open when key is on and then close and wont reopen.
You might also want to check to see if you vehicle has an anti theft function i have the 95 lebaron and if the anti theft is activated it starts runs for a few second and dies. if battey dies or is replaced i have to go to the passenger door and put in the key and turn it 4-5 times then it starts and runs so try this first.
Read more: http://wiki.answers.com/Q/Why_does_my_1995_chrysler_lebaron_start_but_only_runs_for_seconds_what_are_the_possible_problems#ixzz1Pmb08o4d
Aug 05, 2010 | 1995 Chrysler LeBaron
Starts then dies
check your fuel pump relay
Mar 06, 2009 | 1998 Buick Century
1998 cad alarm no start
Your GM product has a safety alarm, it shuts down the radio , or locks it.
I send ours to a GM dealer to get it unlocked. They don't give those codes out.
Jan 15, 2009 | 1998 Cadillac DeVille
2003 Chevy suburban dies while driving
eather it is the alatanoter over heating or the coil probly the coil i would beleave
Dec 14, 2008 | 2003 Chevrolet Suburban 1500
Psi 2500 Mobile Pressure Washer 5hp Honda Engine Logo
35 people viewed this question
Top Psi Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Psi Tool and Hardware - Other Expert? Answer questions, earn points and help others
