Mitsubishi WD-52628 52" Projection HDTV Logo
Posted on Jun 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Timer light blinks constantly
Theres a timer light next to the power button and a few weeks ago it started blinking fast. The light is a green light marked timer. I replaced the bulb with a new bulb from mitsubishi and no difference so pretty much now my tv wont turn on it doesnt do anything and that light just blinks. I dont see anything for this in the buyers guide as far as troubleshooting and i just want my tv back. Anyone else had this problem?
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Jun 29, 2009
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2955250
Points
33084
Is it Mitsubishi WD-52628 TV? please confirm model number.
Unplug TV from AC outlet for couple of minutes, replug back in, turn power ON and check, still same problem?
Lets read error code in TV, press Device and Menu buttons on front of TV at same time for 6 seconds that will activate error code read process. Led will flash in 2 sequence with half second pause. count it and let me know the error code to proceed.
Thanks.
  • Anonymous Dec 27, 2011
    mine is doing the same thing and I pressed the menu and device at same time then it flased with 3 blinks pause then 2 blinks, did that about 3 or 4 times, any suggestions, thanks
I have a mitsubishi dlp WD-65733 and it went out on me a week ago. when I power it up i get only the green light above the timer. when i hit the reset button in the front i hear a click in the back and the...
It seems problem in power supply board that got few electrolytic capacitors leaky and causing problem. It does not look like lamp issue.
Let me know are you handy with electronics stuff repair and can replace parts in circuit board?
Thanks.
Big Screen Televison problem
1) pull chassis ( requires un-hooking extensive wire runs)
2) turn chassis upside-down
3) solder any / all bad connects,esp. regulator pins
Look for electrolytic capacitor leakage evidence =
dark,discoloration of trace material
4) replace any bad capacitors
5) re-install chassis and test
1helpful
Tv will not turn on. timer light constantly blinks
If you can get into the main menu go to load factory default and reboot, This will reload factory settings and this operation will erase all unwanted settings and load back to factory default. so you can load your own settings and take back control of your tv.
Blinking Green Timer Light
I suspect the lamp area is VERY dirty as is the cabinet's filters and fans. This causes great stress on your tv and lamp. Take the time to clean all of them fully. Is the unit in a dirty area? or in a high temp area? DLP's dont like high temp or contaminated areas as they are NOT air sealed units.
1helpful
6helpful
3answers
Mitsubishi Model WD-52725 timer green light blinking fast
My Mitsubishi WD52725 will not turn on...the timer light is blinking. We pushed the reset button, unplugged tv. Just got off the phone with Mitsubishi customer "service." After answering numerous personal questions, and being on hold for several minutes, I was told that the only solution was to push the reset button. Duh! We'd done that several times with no change, which is why I called them! BIG WASTE OF TIME!!!!
2answers
Blinking Green Light on Mitsubishi DLP 52525
Replace the 1000uf capacitors on the DM board. thats whats causiong the problem. If you need further help go to this link they have your service manual available for emailing after purchase and that will entitle you for free tech support and one of their techs can fix those sets in his sleep he will walk you through the repair which parts are only about 20 dollars to fix the problem.
http://servicemanuals.vstore.ca/
2answers
No problem, do self diagnosis test, read threads here or goto ctechnicians.com get error codes first and get back with me.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
