2006 Saturn Vue Logo
Evette Murray Posted on Jul 22, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Show me how to repair a cv joint Saturn vue 2006?
automaniac
Level 2:
Habit-Forming:
  • Expert 144 Answers
  • Posted on Jul 22, 2014
automaniac
Expert
Level 2:
Habit-Forming:
Answers
144
Questions
0
Helped
66576
Points
288
Transaxle Removal & Installation
Fig. Disconnect the shift control cable (3) from the range select lever (4)
  • Remove the upper transaxle to engine bolts (1, 3, 5, 6) and stud (2).
    Fig. Remove the upper transaxle to engine bolts (1, 3, 5, 6) and stud (2)
  • Safelshow me how to repair a cv joint Saturn vue 2006? - 0996b43f80205834.jpg.
  • Remove the transaxle mount to transaxle bolts.
    0996b43f80205834.show me how to repair a cv joint Saturn vue 2006? - enlarge_icon.gif
    Fig. Remove the transaxle mount to transaxle bolts
  • Remove the transaxle mount to show me how to repair a cv joint Saturn vue 2006? - enlarge_icon.gif.
    Fig. show me how to repair a cv joint Saturn vue 2006? - 0996b43f80205836.jpg mount to frame rail bolts
  • Remove the left transaxle mount
  • Raise and safely support the vehicle.
  • Remove the splash shield.
  • Remove the bolts (2, 3) from the transaxle brace.
  • Remove the transaxle brace (1).
    Fig. Remove the bolts (2, 3) from the transaxle brace
  • Remove the starter.
  • Mark the relationship of the flywheel to the torque converter for reassembly.
  • Use the J 43653, Flywheel Holding Tool, to prevent the crankshaft from rotating.
  • Remove the torque converter to flywheel bolts.
  • Remove the nut holding the transaxle cooler line retainer to the transaxle.
  • Disconnect the transaxle cooler lines from the transaxle.
  • Disconnect the Vehicle Speed Sensor (VSS) wiring harness from the sensor.
  • Disconnect the tie rods from the steering knuckle.
  • Disconnect the stshow me how to repair a cv joint Saturn vue 2006? - enlarge_icon.gifinks from the stashow me how to repair a cv joint Saturn vue 2006? - enlarge_tooltip.gif
  • Disconnect the ball joints from the steering knuckles.
  • Remove the frame.
  • Disconnect the wheel drive shafts from the transaxle.
  • Support the transaxle with a suitable jack.
  • Remove the lower transaxle to engine bolts (5, 6, 7, 8).
    Fig. Remove the loweshow me how to repair a cv joint Saturn vue 2006? - enlarge_icon.gifngine bolts (5, 6show me how to repair a cv joint Saturn vue 2006? - enlarge_tooltip.gifclass="h_mi">Separate the engine and the transaxle.
  • Remove the transaxle from the vehicle.
  • Flush the transaxle cooler and the lines with J 35944-A, Transaxle Oil Cooler Flusher.
  • Remove the following only if replacing the transaxle.
    1. Remove the shift cable bracket bolt (3), nut (1), and bracket (2).
    2. Remove the PNP switch.
    3. Remove the transaxle mounts.
      Fig. Remove the shift cable bracket bolt (3), nut (1), and bracket (2).
  • To install:
    1. Install the following if previously removed
      1. Install the shift cable bracket (2), bolt (3), and nut (1).
      2. Tighten the bolt (3) and nut (1) to 16 ft. lbs. (22 Nm).
    2. Install the PNP switch.
    3. Install the transaxle mounts.
    4. Position the transaxle in the vehicle.
    5. Install the lower transaxle to engine bolts. Tighten the bolts to 55 ft. lbs. (75 Nm).
    6. Install the wheel drive shafts to the transaxle.
    7. Install the frame.
    8. Lubricate the transaxle cooler pipes before inserting into seals.
    9. Connect the transaxle cooler pipes to the transaxle.
    10. Install the transaxle cooler pipes retainer nut. Tighten the nut to 62 inch lbs. (7 Nm).
    11. Use the J 43653, Flywheel Holding Tool, to prevent the crankshaft from rotating.
    12. Install the torque converter to flywheel bolts. Tighten the torque converter bolts to 44 ft. lbs. (60 Nm).
    13. Install the starter.
    14. Install the frame.
    15. Install the steering gear intermediate shaft pinch bolt.
    16. Connect the ball joints to the steering knuckles.
    17. Connect the stabilizer shaft links to the stabilizer shaft.
    18. Connect the tie rods to the steering knuckle.
    19. Connect the wiring harness to the VSS.
    20. Install the transaxle brace.
    21. Install the transaxle brace bolts. Tighten the bolts to 39 ft. lbs. (53 Nm).
    22. Install the front splash shields.
    23. Install the front wheel and tire assemblies.
    24. Lower the vehicle.
    25. Install the left transaxle mount.
    26. Install the upper transaxle to engine bolts and stud. Tighten all of the bolts and stud to 55 ft. lbs. (75 Nm).
    27. Untie the radiator, air conditioning condenser, and fan module assembly.
    28. Remove the engine support fixture.
    29. Connect the transaxle wiring harness to the main transaxle electrical connector, and the PNP switch.
    30. Install the shift control cable to the shift control cable bracket. Ensure the cable retaining clip is fully seated.
    31. Connect the shift control cable to the range select lever.
    32. Connect the air duct hose to the intake plenum.
    33. Install the battery tray.
    34. Inspect the transaxle fluid level.
      NOTE
      It is recommended that Transmission Adaptive Pressure (TAP) information be reset. Resetting the TAP values using a scan tool will erase all learned values in all cells. As a result, the ECM, PCM or TCM will need to relearn TAP values. Transaxle performance may be affected as new TAP values are learned.
    35. Reset the TAP values
    1 Related Answer
    Anonymous
    • 3911 Answers
    • Posted on Dec 21, 2010
    SOURCE: replacing a cv joint shaft on my 2006 saturn vue
    get a repair manual on CD, about 10 bucks. there are several steps involved and you will need the pictures. assume you have a garage full of mechanic's tools.
    1helpful
    2answers
    Locate the TCM on 2006 Saturn vue
    Transmission Control Module (TCM) (MN5)
    In the passenger compartment, under the left side of the I/P
    How do i repair a cv joint for a Saturn Vue 2006
    the cheapest repair here is to have a reconditioned unit fitted to the vehicle . To do it yourself will only repair 1/2 the joint and it will fail early
    Show me hoe to repair a cv joint for a Saturn Vue 2006?
    Buy the shaft assembly instead of trying to change the cv joint on your shafts. They aren't much more expensive and will save a ton of time. Remove wheel, brakes, rotors, axle nut. Slip the shaft inward and press out if the hub. Then simply pop it out of the other end. There is a retainer clip on the differential side that springs in and out of place. A prybar or long screw driver helps pop it past the detent.
    I have a 2002 Saturn Vue 5-speed. As I slow down, there is a clicking sound, even if I am in neutral. Is that the differential? What can/should be done?
    IF THIS "CLICKING" SOUND IS WHILE TURNING, CHECK BOTH FRONT DRIVESHAFT INNER AND OUTER C.V. JOINT BOOTS. IF TORN, YOU MOST LIKELY HAVE A BAD C.V. JOINT
    2helpful
    2004 Saturn Vue w/30,000 miles. When I turn right or left I get a clunking noise from front end.
    it could actually be a few things, but here are the ones you should check.....front hub bearings, cv axles, and upper or lower ball joints
    Replacing a cv joint shaft on my 2006 saturn vue
    Dear sir yes i ment cv joint & no it does
    CLUNK NOISE YOU HEAR IS WORN CV JOINTS.
    Wining high pitch and clicking in right front wheel can the transmission be serviced?
    Doesn't sound like transmission if comming from only right front side. Maybe a wheel bearing or axle , cv joint.
    A little suspension work and alignment should cure it.
    2006 Saturn Vue Wheel Bearing
    it should come out once you have disconnected:Brakes,strut,ball joint.tire rod end,cv joint!if it is not put the cv joint nut back on until safe enough to give it a tap with hammer to knock back & out shaft this should come as one piece HUB the bearing is pressed in! better to change whole HUB good luck this hopefully helped you out!
    Top Saturn Experts
    ZJ Limited
    ZJ Limited
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Thomas Perkins
    Thomas Perkins
    Are you a Saturn Expert? Answer questions, earn points and help others
