1999nighthawk 250cc cbx
Remove the switch and detach at the harness connector. If the bike starts now you have bypasses it. If it doesn't start you will need to make a jumper wire and connect that to the harness where the switch used to plug in. Which method will work depends on if it is set up to be normally open or normally closed to run. One of these two methods will work for you though.
