Display fast flashes between "grounds full" and "Descale" symbols
SOURCE: talea giro plus. csan't exit descale cycle
Keep pressing the water button for 6 secs until the flashing light goes off.
SOURCE: My Saeco Talea Giro have the wave like symbol with
It is saying..it's time to descale the machine. If you want to get rid of it, just press the water button and hold it for 5 secs.
SOURCE: how do I descale my saeco talea giro plus before
Hello your machine specificlly says in the manual The descaling must be done when indicated by the machine. Click this link this is the manual to your machine
http://www.italianlifestyle.co.za/content/manuals/taleagiro.pdf if you are having an issue with the amount of water coming out of the unit you can use a pin or a needle on the nozzle head page 18 in the manual describes the weekly steps that must be taken to clean the machine as well as the brewer area of the machine. If you have any futher questions message me back Thanks
Rick
SOURCE: how to descale machine talea giro plus
Many times if you perform once more descale the problem can be solved so here is a video that can help to repeat the descale
SOURCE: talea giro descale already done but red led of descale has not gone
I was told by tech that if you hold the water button in for a few seconds then this resets. It depends on what kind of water you use too. If you use filtered or spring water then you don't need to descale it as often and you can override this by above method. Hope that helps.
