Run what ever fuel/oil mix you are comfortable with. A run lean condition is most often caused by an undetected air leak leaning out the mixture to failure. A couple of ounces of 2-cycle oil will not prevent its occurrence. If an owners manual (OM - I tried) is ever located it likely says 32:1. Most modern saws recommend 50:1:
Oil Mix Ratio:
In the early to mid 90s Dolmar, Echo, efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear
