Question about Hoisting
Repco hoist koni 3580
Safety pawl right side
    New Friend:
  • 3 Answers
But I will say that you don't have to be doubt about any of our products we are here to satisfy your want
Posted on May 19, 2019
  • 2,210 Answers
What about it?
If you have doubts about a safety related item get an engineer to call.
Posted on Jul 21, 2014
SOURCE:
Prints half page
It is because of a split little white pawl on a rod above the cartridge on the right hand side of the printer.
The pawl pushes down the print head and when the pawl splits, it doesn't push down far enough to print on RHS.
I've tried using a tie strap to repair it but it interfers with adjacent parts.
Jun 25, 2014 | Canon Selphy CP510 Thermal Photo Printer
What is OSHA and why do they need to inspect my wire hoist every year?
OSHA is the United states department of labor Occupational safety and health administration. They have to inspect your wire hoist every year to make sure that you and your employees are safe when they are using the wire hoists in your facility.
Nov 21, 2013 | Hoisting
How doi remove right side engine mount 1992 buick lesabre
My first question is--why are you trying to remove the engine mount?
Is the engine mount bad? Is this a V8? Does right side mean Passenger side or Driver side? Is the engine in there sideways e.g. --the belts on the passenger side?
Usually, there is a bolt from under the vehicle that goes through the frame or mounting bracket. Then, there are usually two bolts going to the block.
Ideally--you need an engine hoist (cherry picker) to support the weight of the engine while you remove and replace an engine mount. This can be very dangerous if you do not have an engine hoist!!! However, you can use leverage as a tool (e.g. -4X4; steel pike; floor jack w/4X4)--but run the risk of bending or breaking parts in your engine compartment. You can find and crack loose the bolts (do not take out) then lift the engine with your 'method' to 'test' the safety of your lifting method. Keep your hands out and be careful.
Hope this helps.
Nov 09, 2013 | Vehicle Parts & Accessories
I have a 2004 chevy silverado and i'm having trouble getting the spare tire to lower. It lowered about 3 or 4 inches but now it seems the cable is off track in the hoist. I believe the cable is jammed...
Cut the cable and if the wheel is even usable
from rust,don't put it back under in the weather
That is one of the car makers stupid ideas
It rusts in place so you have no spare
Mine fell out on the street while driving, after it rusted
away ,and the wheel brought tears to your eyes
Mar 19, 2011 | 2005 Chevrolet Silverado
The door does not close on the right side on my deskjet 6980
On the HP 6980 et al printers the right side of the lid does not completely close. The reason is a design flaw. If you pull the bottom of the right side cover out no more than 3/8" to release the clips and then lift it up you will reveal the lid gears and lid closed switch pawl. The area where the switch pawl contacts the lid gear needs generous lubrication. If that fails then removing the sharp edges of the contacting areas will be required and then the lubrication.
Jan 26, 2011 | HP Deskjet 6980 InkJet Photo Printer
Manual chain hoist keeps slipping load chain when under load (lifting and lowering). It will hold when you keep tension on the slack side of load chain. Any ideas?
sounds if the motor brake is not holding , this is a wear part and will require adjustment/replacement over its life time , the brake is located under the motor cover , but if your not sure what to adjust ,then im gonna suggest for safetys of you and the people around it' s sake you get a profesional to service this hoist
Aug 19, 2010 | Jet Equipment Chain Hoist 1TON 10 Ft Lift...
Faulty Repco sports treadmill
Not really familar with this brand but if it has a safety key, check to make sure it properly inserted and making proper connection.
Jun 05, 2009 | Exercise & Fitness
I've got a 3580 Ultrium tape drive with a tape that won't eject and the unit displays error code 6. Is there a trick to get the tape out?
I had this same problem a few mins ago. I held the tape up with my finger as I hit eject. The tape came right out. Then I put in a cleaning tape and had no issues at all. You don't need to disassemble the unit at all.
Jan 06, 2009 | IBM TotalStorage 3580 L33 (3580L33)...
Hoisting Logo
870 people viewed this question
Top Hoisting Experts
AZBen
AZBen
Andrew Taylor
Andrew Taylor
Pierre Laplante
Are you a Hoisting Expert? Answer questions, earn points and help others
