How to transfer pictures from iphone to facebook
To transfer pictures from iPhone to Facebook, you will need an iPhone transfer software like Leawo iTransfer. After downloading and installing this software on your computer, you can follow the steps below to transfer pictures from iPhone to Facebook.
Step 1: Connect your iPhone to computer and launch the software.
Step 2: In the left sidebar, click Photos library and you will find all your iPhone photos displayed in the right panel. Choose target photos.
Step 3: After selection, right-click them and choose Transfer to > Computer. In the pop-up window, set the output directory.
Step 4: Open Facebook on the browser of your computer. And upload pictures from the directory you set just now.
Download Facebook app on your iPhone 4s or plug your phone into your computer.
SOURCE: Unlock iPhone 4s to AT&T network
hi ,you need to factory unlock your phone...please post your IMEI number so we can see if what is the carrier...you pay a little bit money to unlock it..
SOURCE: Iphone 4s shins
Step 1: Clean your workspace. Be sure to get a flat, hard surface without a lot of fabric, liquid, dust, etc.
Step 2: Lay the phone down and clean it well with the cleaning cloth provided. Do not use any kind of cleaning fluid or water, but try to be sure that all fingerprints are gone. Especially be sure no dust or lint particles are on the screen. Before proceeding be sure that there are not a lot of dust particles gathering near you, vaccum and clean the area up a bit more if need be. You want as sterile an area as possible before continuing.
Step 3: Being careful not to touch the sticky side of the screen protector, peel back the tab where indicated. Hold the screen protector only by the sides and line it up with the phone. If you touch the sticky side of the screen protector by accident do not try to clean it off, you will only make it worse. Line up and let the screen protector fall into place from the top of the phone to the bottom. Some people choose to use a credit card or thin piece of plastic to smooth out bubbles as the screen protector makes contact with their device, however this is usually not recommended by the makers of the screen protectors or the phone. The choice is yours, but bubbles are meant to smooth out over time, so take that into consideration.
Steap 4: Once the screen protector is on the device if it is straight and you can see bubbles but no lint or dust beneath it, you are successful, give it a few days for the bubbles to dissipate. If it is not on straight, you may be lucky enough to be able to lift it up and place it better without fault, however this is risky. If lint or dust has gotten between your phone and the screen protector you have likely failed, there is little recourse from here, other than removing the screen protector, cleaning the device, and trying with a new screen protector altogether.
SOURCE: iPhone 4S Issues/Will Not Turn On
Hello, First check to see that your power cord is working to charge your unit. Then remove the battery and let set for 2 mins and then put back into unit. If this doesn't fix then you will have too call cust service or tech support for iphone and work with them. May have too send in too have repaired.
