There is a known issue with a bad resistor in the display board. Which resistor is at fault? If I know which resistor and what value it is I can replace it myself.
The bad resistor is on the ps board that drives the display, well on mine at least. The resistor is supposed to be 10 ohms at 1/8 watt "i think" i replaced it with a 1/2 watt resistor. Either way its R9310. the board is right behind the display on the right side just behind the volume knob. when open and looking from the back you see it just fine. it's not hard to get out. fairly simple to fix.
