Have red light flashing on the computer
SOURCE: dell inspiron 6400 touchpad and keyboard work
sounds like your main battery needs replacing,move your mouse over the battery icon in the system tray(by the clock),to see if the battery is charging. If it is battery needs replacing. This can cause all kinds of strange issues .
SOURCE: 3 lights o right hand side of laptop what do they mean
The user manual will supply an in-depth explanation of the led-indicators, aswell as there are normally small icons assigned to each light, sometimes engraved in the plastics, normal lights to be active at average usage are the Power led indicator, will glow as long as device is turned on, the Wireless led indicator will glow when the wireless network module is active, the CPU led indicator will flash occasionally when system is idle, and rapidly when system is active under load, and the Battery led indicator will be active when device is running on battery power. When device goes into sleep or hibernate mode the sleep led indicator might continuously glow or slowly switch on & off varying between systems.
SOURCE: my dell inspiron 6400 won't
The following troubleshooting guidelines are basic troubleshooting steps.
Battery Charging
It is recommended to charge the battery while the system is off for
faster charge times. Users may notice longer charge times when the
system is powered on and running graphics extensive applications.
No POST
If the system does not perform a Power On Self Test, there are various things to look for:
Video
If the LCD on the system shows no display, or has other LCD problems, there are some basic steps to take:
SOURCE: Dell Inspiron 6400 - manually flash BIOS
I just went through this myself - you can fix it, but you need access to another PC to do so.
Start by downloading the latest BIOS update from the Dell website, then open a command prompt and execute the BIOS update file with the -writehdrfile parameter - in my case, the command was:
mm061a17.exe -writehdrfile
This should create a file with the name "mm061a17.hdr" - copy this to a FAT16 formatted USB stick and plug it into one of the USB ports on the laptop. Remove the battery and AC adapter cable.
Then hold down the 'END' key on the keyboard and plug the AC cable back in - the power light should come on. Finally release the 'END' key and the system should start to read the USB stick, reflash the BIOS and finally reboot.
