I cannot find the owners manual for my Holmes fan and would like to take the front cover off to clean the blades. Suggestions?
SOURCE: Cleaning
After you have the front cover off, you'll see the center screw cap that holds the blade on. Simply unscrew it...BUT, typically you would unscrew a nut by turning it counter-clockwise. Instead, this cap is threaded the opposite way, so you have to twist it off turning clockwise.
After you have the screw cap off the blade slips off and you'll see that the back has a screw cap also (or at least my model does). It has regular threads so it screws off counter-clockwise and then you can slip the back off.
Its very easily done and requires no tools to do. Hope that helps you....Dan.
SOURCE: i have a holmes blizzard fan and need to clean the
Turn the fan around there are four screws on the backside of the grille. You will need a long philips head screwddriver.
SOURCE: I can't get the shield
Additionally this diagram information could helpfull: SAF-16%20Stand%20Fan.
Hope helps.
