The coffee machine isnt functioning properly. The machine is leaking water into the drip tray and filling it quickly
I've had this issue a couple of times. The water just goes straight through to the drip tray and the pod doesn't get pierced. The first time it was fixed under warranty but the 2nd time Nesspresso wanted $150. I took the back off the machine myself (very easy, just unplug it from the wall, remove the 4 screws and unclip the back cover) and saw that the $3 flowmeter had been replaced at the first repair (it had a date on it which was after we purchased the machine). It's the white thing at the bottom right and very easy to remove, (Take a photo of it so you know which way it goes, then just pull off the electric plug, unclip it and take off the 2 water tubes). I couldn't see anything wrong but blew through it a few times and put it back...........its since been working perfectly for over a month now, (I think microscopic solids from the water supply can block it). The whole process shouldn't take more than 10mins.
