Question about Leisure GRB6CVK Electric Cooker with Ceramic Hob, Black
What do I need to do to screw the oven door back to my leisure Alta cooker? Any suggestions?
I had take the oven door apart to change to change the locking mechanism but when trying to screw the door back to the oven I could not because the 2 small plates onto which the screws where attached had fallen behind the oven front panel (they were held by the screws). I unscrewed the 4 screws holding the panel to the oven but it is not coming off. I don't know how to take that panel off.
    Genius:
  • Leisure Master
  • 2,548 Answers
Try hooking the plate with a piece of wire and pull it close to the hole's,then get a strong magnet and put next to the screw holes,it might hold the plate till you get the screws started.
Posted on Jul 20, 2014
Testimonial: "Thanks Richard. I'll try this but the plates are right at the bottom so will be tricky"
  • Stephan Apr 01, 2015
    Had the same issue and I still can't get the hinge back on!!
SOURCE:
When I turn on my oven for cleaning it shows a f9 problem...could you help me with that
An F9 error code on a General Electric oven indicates that the oven's electronic control system has detected a problem with the automatic door lock. The automatic door lock mechanism prevents the oven door from being opened when the oven is set for "Clean" mode. The malfunction may be a jammed door lock mechanism, a pinched or broken wire, a faulty lock switch or a fault in the control board itself.
Things You'll Need:
  • Ohmmeter or multimeter
  • Phillips screwdriver
#step1
Disconnect power to the oven.
Step 2
Open the oven door. Remove three screws from underneath the oven's control panel. Lift the control panel straight up to disengage the mounting pins on the top corners of the panel, then tip the panel toward you.
Step 3
Inspect the door lock mechanism. The mechanism is in the lower left area of the space behind the control panel. Rotate the cam on the door lock mechanism to be certain it moves without binding. Replace the mechanism if its mechanical parts do not function properly.
Step 4
Inspect the wires that connect the door lock mechanism to the control panel. Check for pinched or broken wires. Check for wires with frayed insulation. Repair wires as needed if defects are present.
Step 5
Locate the six-pin connector on the door lock motor on the right end of the door lock mechanism.
Step 6
Rotate the cam on the door lock mechanism to the unlocked position. Test the resistance between Pin 3 and Pin 1 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 2 of the door lock mechanism if the resistance reads other than 0.
Step 7
Rotate the cam on the door lock mechanism to the locked position. Test the resistance between Pin 3 and Pin 2 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 1 of the door lock mechanism if the resistance reads other than 0.
Step 8
Contact a certified repair facility if the source of the F9 code has not been discovered.
Troubleshooting the oven with the electric power turned on is a job for a certified technician.
Do not perform troubleshooting on the oven with the power connected. Personal injury and damage to the oven can result.
Aug 04, 2010 | Microwave Ovens
Got error code F9 while oven cleaning in process. What does this mean?
An F9 error code on a General Electric (GE) oven indicates that the oven's electronic control system has detected a problem with the automatic door lock.
9 out of 10 times the lock switch has failed.
STEP # 1 - Disconnect power to the oven!!
  • Step 2 Open the oven door. Remove three screws from underneath the oven's control panel. Lift the control panel straight up to disengage the mounting pins on the top corners of the panel, then tip the panel toward you.
  • Step 3 Inspect the door lock mechanism. The mechanism is in the lower left area of the space behind the control panel. Rotate the cam on the door lock mechanism to be certain it moves without binding. Replace the mechanism if its mechanical parts do not function properly.
  • Step 4 Inspect the wires that connect the door lock mechanism to the control panel. Check for pinched or broken wires. Check for wires with frayed insulation2_bing.gif. Repair wires as needed if defects are present.
  • Step 5 Locate the six-pin connector on the door lock motor on the right end of the door lock mechanism.
  • Step 6 Rotate the cam on the door lock mechanism to the unlocked position. Test the resistance between Pin 3 and Pin 1 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 2 of the door lock mechanism if the resistance reads other than 0.
  • Step 7 Rotate the cam on the door lock mechanism to the locked position. Test the resistance between Pin 3 and Pin 2 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 1 of the door lock mechanism if the resistance reads other than 0.
  • Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Apr 01, 2010 | GE Profile JTP56 Electric Double Oven
    It won't get to temp, then it beeps and it says f9...it continues to beep, and inside light is off
    Contact a certified GE appliance repair facility if the source of the F9 code has not been discovered. Troubleshooting the oven with the electric power turned on is a job for a certified technician.
    Mar 05, 2010 | GE Monogram® ZET3038 Dual Single Oven
    Oven door lock does not unlock, I turned on the self clean mode and then changed my mind and turn it back off about 3 minutes later. But it does not unlock. The lock light is blinking.
    Hi
    Thanks for using FixYa. There is an over-temperature switch built into the electrical panel of the oven. Resetting this switch might solve the issue.
    To reset it: Turn off the power. Open the door (if door is locked, turn the power back on and gently try pulling the door every few seconds as the locking mechanism cycles until it is unlocked). Remove the 3 screws below the control panel (screws point upwards, with the head just inside the oven). Pull off the face of the control panel. Let it dangle by the wires so that you have access to the space behind it.
    Within the electrical enclosure exposed by removing the control panel, look for a small silver and black device with 2 wires attached to the back. The device is about .5" wide by 1" long and is attached with 2 screws to the sheet metal on the bottom of the electrical enclosure.
    Please do rate the solution and revert for further assistance.
    Thanks
    Rylee
    Nov 26, 2009 | Electrolux E30DF74PS Dual Fuel (Electric...
    Wont unlock after self cleaning
    Hi
    Thanks
    Rylee
    Nov 26, 2009 | Jenn-Air Ovens
    I cleaned my Jenn-Air oven and now cannot get the door unlocked?
    Hi
    Thanks
    Rylee
    Nov 25, 2009 | Jenn-Air Kitchen Ranges
    Cleaned oven door lock wont release, cant cook
    Hi
    Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
    Nov 23, 2009 | Frigidaire FEF336BC Electric Kitchen Range
    Door remains locked
    Hi
    Thanks
    Rylee
    Nov 23, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    After self clean the door will not unlock. Tried resetting circuit breaker several times. Tried to restart the cleaning and cancel after 15 min. Tried restarting cleaning and cancel after 1 min. Tried...
    Hi
    Thanks for using FixYa. There is an over-temperature switch built into the electrical panel of the oven. Resetting this switch solved my problem.
    Thanks
    Rylee
    Oct 19, 2009 | Kitchen Ranges
    Bottom screw on handle loose
    All my micros had the screw go through the handle into the micro...no need to take door apart, just screw it back in. Why would you need to take the door apart?
    Jun 12, 2007 | KitchenAid KHHS179LSS Convection /...
    Leisure GRB6CVK Electric Cooker with Ceramic Hob, Black Logo
    207 people viewed this question
    Top Leisure Kitchen Ranges Experts
    Andrew Taylor
    Andrew Taylor
    Chuck Graybill
    ray gallant
    ray gallant
    Are you a Leisure Kitchen Range Expert? Answer questions, earn points and help others
