The air conditioner turns on, compressor cuts in, but the fan/fan motor doesnt work. I need to find a part number for the fan but am having difficulty finding the model on the internet.
SOURCE: hisense air conditioner
-If both compressor and fan motor starts and stop, thermostat is the defect.
- If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
SOURCE: blower motor in home air conditioner does not work
The most common failure for this problem is either the start/run capacitor or the fan motor. IF YOU ARE NOT experienced with electricity then I would strongly suggest hiring a technician. The volts are 220 with a potential of 50 amps in a common residential unit.
If you are knowledgeable in this area then make sure the motor has volts to it. If it does have volts and does not spin, it is bad. You can sometimes tell by feeling the motor it will probably be very hot. The compressor will eventually shut itself off when it over heats. It usually will restart after it cools down(sometimes many hours). The motor and capacitor are pretty generic and can be matched up at a local Grainger store or whatever Retail, specialty store that you have in your area.
I hope this helps:)
SOURCE: how to replace window air conditioner fan motor
Most of the time I go in from the top of unit with pkiers to remove clip. Once the clip is loose. Hold the shaft with channel locks and the fan should spin. Russ
