Tomy Thomas The Tank and Friends Track Logo
A
Anonymous Posted on Jul 20, 2014
Rumble in the jungle board game instructions
I have just been given this game but it has no playing instructions
Halex 64307 Dart Board. I need a manual for it please?
Question turned around for clarity.
Is this it? The board used special darts, you can't use metal tipped darts.
Halex ZETA Owner's Manual - ManualsLib
ManualsLib https://www.manualslib.com > ... > Toy
View and Download Halex ZETA owner's manual online. Electronic Dartboard. ZETA toy pdf manual ... Owner's Manual and Game Instructions. Unpacking the Game.
More here, but not that model number, is it correct?
https://electronic-dart-board.blogspot.com/2016/12/halex-electronic-dartboard-manual.html
The soft tip darts are available on Amazon.
https://www.google.com/search?q=halex+64307+soft+tip+darts
2answers
I was given the board game Pirate-opoly but without the instructions. My kids are excited to play it but we need the rules and instructions. Can anyone help me?
Hi, I wrote to them last night and they returned the instructions this morning. I will attach them here and will upload them to our website shortly. Have fun!
(Please click the 'HELPFUL' button? Thanks!)
It hooks up to my labtop computer but it won't play in any of my games
you need to install drivers for it and go to the web site that sells it and you can download them for free. then you have to calibrate all buttons with the instructions give after you have loaded the drivers for the game pad.
Just bought a boomchair SVC and the rumble on it will not turn off. Any ideas?
I have the same problem, and after cutting the bottom open to get to the mainboard, I discovered that playing with the 4 pin (2 brown, 2 white) connector between the two boards on the main board seems to calm it, and stop it from vibrating.. I just can't get it to stay off. Bump for help!
Dk jungle climber freezes
Yes,its due to many reasons. its general, may b there is some missing gamefile or the installation was not done properly at that time, it also due to some system inreq.ment. so i suggest to reinstall it otherwise remove it because it may harms ur system
My Sony Trinitron KV-AR34M86 is showing 5 blinks every 2-3 seconds interval while powered on. Display is also pinkish. Please help. I can work down to component level provided instruction is given. Thanks...
Hi
please try to check the board at the Jungle Chroma section, check the supply voltages tru Jungle IC then check the Regulator of Jungle power supply if this is 5, 8. or 12Volts. please check. if the requirements is same by the given regulator viltages.
Thanks!
1helpful
2answers
Can't play StarCraft - what kind of pack do we need and where do it go in the system
The rumble pak is optional, all it does is shake the controller during gameplay. The expansion pak is required to play the game. It increases the Ram inside the console to 8MB. Some games its is optional, While others it is required.
Donkey Kong 64, Perfect Dark, Starcraft 64, The Legend of Zelda: Majora's Mask all require it for all the feature to be accessable. There may be other games that use it but they do not require it for the most part
1helpful
3answers
No commentary (disappeared after short use) and no Rumble feature
Solved the commentary problem, make sure the speed play is off and saved. We are back in business
Setting up rumble pad
Ok well here is what i did for using the direction pad to play flatout, a pc racing game, using the Wireless rumblepad 2 controller. First open up profiler, click on d-pad, select assignment, then click new POV assignment. Put a check on FPS style movement. Then click edit, then click new keystroke. Hit record and then on the keyboard hit the up, down, left and right keys. Then hit stop and click ok. click cancel on the window right behind it. So now you are viewing the POV assignment window that we opened before. Here what you do is, say for instance hit the "N" button and then to the right of it you see "pov north", hit the scroll down menu and hit "keystroke Up" for N. Like wise you click the "E" button and for POV east you assign "Keystroke right". And so like wise "keystroke down" for "S" and "keystroke left" for "W". Once you have all that done. You hit ok and just open up whatever game you want to play and the Direction pad should be able to allow you to steer or go in the up, down, left or right direction. Hope these instructions help solve your problem.
Top Tomy Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Tomy Toy Expert? Answer questions, earn points and help others
