Move a page break
Important To enable dragging of page breaks to another location in a worksheet, make sure that the cell drag-and-drop feature is enabled. If this feature is not enabled, you may not be able to move any page breaks.
To verify that drag-and-drop is enabled, do the following:
Click the File tab.
Note: Moving an automatic page break changes it to a manual page break.
Delete a manually-inserted page break
Note You cannot delete page breaks that Excel has added automatically. Adding manual page breaks, changing the page orientation, or adjusting column widths and row heights may affect automatically-inserted page breaks.
To delete a manually-inserted page break, do the following:
Note If you get the Welcome to Page Break Perview dialog box, click OK. To not see this dialog box every time you go to Page Break Preview view, select the Do not show this dialog again check box before you click OK.
Note You cannot delete an automatic page break.
To delete a page manually, select the page break at the end of the page, and then press DELETE.
To delete a blank page at the end of the document, select the page break or any paragraph markers at the end of the document, and then press DELETE.
