When you pull self propel cable makes whinning noise
Disconnect the spark plug turn the mower on its side and inspect the drive belt on the pulley above the blade (on the crankshaft) it may have a shroud over it. Also there is a small gear case that maybe dry that the belt drives, that goes to the wheels, Also try lifting the drive wheels up off the ground and engage them and see if it still does it. if it stops once lifted it might be the bushings on the axle its self.
SOURCE: Electric Start Spns & won't engage
i have a riding mower and i get that problem sometimes and what i do to fix it is i take a metal pole and put against the motor and gear on the starter and push when it moves i turn the key and that normally fixes it.
SOURCE: Electric start doesn't turn over the engine the first time
Have you checked the battery voltage with a multimeter? It should read 12.2 volts or higher. It sounds like the battery is dead, or the charger is not charging.
It starts after it's run because the magneto is slightly charging the battery, plus a cold engine is more difficult to start -- more friciton when cold.
Charlie
SOURCE: i need a replacment drive belt for murray
hi
please find web site for parts and id of your belt
http://www.partstree.com/parts/?lc=murray&mn=20615x51A+-+Walk-Behind+Mower+%282000%29
part number is ref number 28 in the diagram
& murray pt number 037x99
partstree site is good site
cheers paul
Maybe the engine is running with the fuel from the primer bulb (about few seconds), the carburator is not working and need to be removed checked and cleaned, the most common fail is a jet clogged.
SOURCE: I have a Briggs @ Stratton self-propelled mower
There is probably water in your carburetor that is keeping the unit from running. When you press the primer bulb you are pushing fuel past the water into the carburetor .. this is why it will start up. Then it will try to pick up the water and then the unit will die. I would loosen the bowl nut on the bottom of the carburetor and dump the fuel from the fuel tank into an approved container. Also you may take the carburetor bowl off and see if you can see some water on the bottom of the bowl. Keep the bowl steady when you remove it. Also, check to see if the carburetor has any corrosion from the water sitting in it. It may have a white "stalagmite" appearance, or a varnish if the fuel was left in it from the last time you ran the unit last fall. If there is any corrosion you may be able to clean it up with some carburetor cleaning spray. This is available at any hardware or automotive store. After you have done this, then put some fresh fuel in the unit and prime it up and see if it will continue to run. If it does not run, then the carburetor needs to be removed and cleaned. To clean the carburetor you will need a thin wire. You can use this wire to probe the holes in the carburetor and "push" any obstruction out of the way and then you can use the carburetor cleaner to make sure the passage is clear. Then blow the holes out with compressed air. This should clean it up. If the unit still does not run then you may have to replace the carburetor with a new one. If you have to get a new carburetor, take in the MODEL, TYPE, and CODE off of the flywheel housing. It is stamped in the metal.
Testimonial: "thank you very much. I followed your advice and I am back in business again."
