RIM BlackBerry Curve 8520 Smartphone Logo
A
Anonymous Posted on Jul 19, 2014
How to do a security wipe on a blackberry
How do u wipe a blackberry, so you can set a new Blackberry ID on the phone?
RONALD CARTER JR
Level 3:
  • Master 438 Answers
  • Posted on Jul 21, 2014
RONALD CARTER JR
Master
Level 3:
Answers
438
Questions
0
Helped
91596
Points
1345
Hello in order to do a security wipe I recommend downloading the blackberry desktop manager. First you should back up your information. Then wipe your phone. Here is a step by for backup.
1. Connect your device using USB cable
2. Click on Backup and Restore
3. Click on Backup button
4. Select the location where you want to keep the backup data
5. Click Ok to proceed
ne 1. Go to Options
2. Security Options
3. General Settings
4. Click Menu button
5. select Wipe Handheld
6. type in blackberry to proceed
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
5 Related Answers
Anonymous
  • 7752 Answers
  • Posted on Jan 01, 2009
SOURCE: how can i unlock my security code on my blackberry 8330?
sorry that is the only way you can do it for now
Anonymous
  • 541 Answers
  • Posted on May 27, 2009
SOURCE: My Blackberry Curve 8320 does NOT have Blackberry Messenger
If you want to install Blackberry Messenger on handheld do the following steps :
  1. Download the latest BlackBerry Device Software from your service provider's web site.
  2. Install the BlackBerry Device Software onto a computer that has BlackBerry Desktop Manager installed on it.
  3. Connect your BlackBerry device to the computer.
  4. From BlackBerry Desktop Manager, double-click Application Loader and follow the instructions in the Application Loader Wizard to install the BlackBerry Messenger application.
Anonymous
  • 630 Answers
  • Posted on Jun 30, 2009
SOURCE: Delete all contacts
Do you just want to delete the contacts? You can select all or some of the contacts and delete them.
You can bacjk up the data using the Blackberry desktop software. to wipe the device
In the device options, click Security Options.
2. Click General Settings.
3. Press the Menu key.
4. Click Wipe Handheld.
5. To delete all third-party applications from your device, select the Include third-party applications check box.
6. Click Continue.
7. Type blackberry
Anonymous
  • 10 Answers
  • Posted on Feb 04, 2010
SOURCE: reset my blackberry 9000 to factory settings need
You can find your pin underneath the battery on the phone. Just keep typing in passwords until it tells you to enter "blackberry" then it may make you enter password one more time. It will wipe.
Anonymous
  • 52 Answers
  • Posted on Mar 01, 2010
SOURCE: Reload software 513 on blackberry bold 9700
you need to call att and they can get you to data support and they can fix it.
I want to delete my blackberry id as I am giving my phone to someone else who will then want to set up her own id
You will have to do a security wipe on your phone ... You Go to settings then security, from which you will locate security wipe
How do I reset my password
is this for your blackberry id ? if so then you will need access to the e-mail address you registered the id with. and you can click on the forgot password link in the blackberry app world under my world and if you dont have this access or cant remember the e-mail address you will have to phone blackberry and speak to a consultant.
or
you can do a security wipe under options and security settings and then device wipe (note this option will erase all your information from the phone)
How to restore blackberry z10
If you went to Settings, Security and Privacy then Security Wipe. The Balckberry will reload and reboot itself, but you will have to set up the wifi again as you will have wiped out the wifi settings and your Blackberry ID. You need to treat the Balckberry as a new unit and set up both. You can use the ID you set up originally. If you are not the original owner you will need to set up a Blackberry ID.
How do I change blackberry id
do a security wipe under security settings in the options menu and then select device wipe (note create a back up of your contacts and other personal files before doing this wipe as all info will be erased
Blackberry problems
Go to options - security settings - security wipe -type the word blackberry and wipe the phone back to the factory settings. Your phone will now be as it was the day it came from the factory - fresh operating system. You will now notice that all your installed programs that you had is gone, but you can get them again from Blackberry App world, but at least your phone will stop rebooting after security wipe
1helpful
How to reset blackberry id
An easy way is wipe phone memory from Options\Security\Security wipe . You will lost all your personal data !!
But you can update firmware on your Blackberry Smartphone < these will save all data and reset Blackberry ID . Use Blackberry Desktop Software - http://us.blackberry.com/software/desktop.html
How do i change my username in my blackberry so i can get a new blackberry id
The Blackberry ID is permanent to the phone's operating system once activated. This is part of their security for the installed data. The explanation why it is done this way is involved. This approach is basically done in case the phone is lost, nobody can directly clone your phone to another one even if they have the password. They would have to do a complicated work-around. They would not be able to make Blackberry software purchases with another phone using your account. The phone and account are locked together.
You can only change the ID by doing a wipe on the phone. Then you must re-install the the OS (operating system). You will not be able to take back the old data from the Blackberry Desktop Link backup software that was entered on the phone with the old ID. If you do so, the old ID will come back.
Use the Blackberry Desktop Link software to re-install the OS. Then you can re-enter all the contacts, and schedules.
Before wiping the phone, you can sync the phone with Hotmail, or sync it with MS Office Outlook. If you are going to change the ID don't bother to make a backup image of the phone.
Once you re-install the OS you can now make a new ID and new ID password. Then you can let the phone re-sync with Hotmail, or you can bring back the contacts and scheduling by syncing the phone back from MS Outlook.
One thing about Blackberry.... If you ever forget your password for the phone there is no back door. Once the password has been wrongly entered more than the allowable amount the phone is wiped and locked out. The process to make the phone work again is fairly involved and a regular user would have to use Blackberry tech support services to make the phone work again. In this case they would have to prove they own the phone, and have a working provider account for it.
Apr 05, 2014 • Cell Phones
1helpful
How do I reset my blackberry ID
you have to do a security wipe from the settings...then after the security wipe...you can setup your blackberry using a different bb ID
1helpful
2answers
10helpful
How to master reset a blackberry pearl 8220
To delete all data and applications from your BlackBerry smartphone, complete the appropriate set of steps below depending on the version of BlackBerry® Device Software you are running. Warning: The following procedures will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the data prior to wiping your BlackBerry smartphone. If content protection is turned on, the process for deleting all data and applications from the BlackBerry smartphone can take up to an hour to complete. Do not remove the battery from the BlackBerry smartphone while data is being deleted. To identify your BlackBerry® Device Software version go to Options > About (For example, 2.6.x.x, 2.7.xx or 4.0.x.x) For BlackBerry smartphones running BlackBerry Device Software version 2.6 Note: If a password is already set go to step 5. On the Home screen, click the ?Options? icon. The Device Options screen is displayed. Click ?Security?. The Security screen is displayed. In the Password field, press the Space key to enable the password. A dialog box prompts you to type a password with at least four characters. Type a password. Click the trackwheel. Type your password again to verify it. On the Home screen, click the ?Lock? icon. The Lock screen is displayed. Enter your password incorrectly 10 times to trigger a security wipe. For BlackBerry smartphones running BlackBerry Device Software version 2.7 On the Home Screen, click the ?Options? icon. The Device Options screen is displayed. Click ?Security?. The Security screen is displayed. Click the trackwheel and select ?Wipe Handheld? For BlackBerry smartphones running BlackBerry Device Software version 4.0 On the Home Screen, click the ?Options? icon. The Device Options screen is displayed. Click ?Security?. The Security screen is displayed. Click the trackwheel and select ?Wipe Handheld?. For BlackBerry smartphones running BlackBerry Device Software 4.1 to 4.2.1 From the Home screen of the BlackBerry smartphone, go to Options > Security Options > General Settings. Display the menu and select Wipe Handheld. Click Continue. Type blackberry, and then press the Enter key. For BlackBerry smartphones running BlackBerry Device Software 4.2.2 to 4.7 From the Home screen of the BlackBerry smartphone, go to Options > Security Options > General Settings. Display the menu and select Wipe Handheld. Select the Include third-party applications check box if you wish to remove third-party applications. Clear the check box if you do not want third-party applications to be removed. Click Continue. Type blackberry, and then press the Enter key.
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
