Hdmi ports not working say playstation 3 out of range in all 3 ports. playstation works on other tv
SOURCE: HDMI AUDIO NOT PASSING THROUGH?
OK try to connect all to tv and from tv connect the sound in digital to H/K receiver and you will have sound at the receiver no matter what.
SOURCE: Sony Bravia television hdmi stopped working
Installing a new software update will this issue. All you need is a compatible USB flash drive. Go to support on Sony.com. Look up your tv model and if there is an update, just follow the instructions to install it yourself. I have a KDL-46S5100 and this worked great. The download and instructions page I used was : http://esupport.sony.com/US/perl/swu-download.pl?upd_id=4769#install
SOURCE: hdmi port stopped working on sony bravia
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
SOURCE: My HDMI inputs #2,3, & 4 no longer work.
Unplug the tv about an hour to let it reset itself.Replug,reset everythings in ur tv menu back to factory setting.All ur functions on the Tuner board should work again.Not than,ur Tuner board is defective,have all those shorted HDMI input Hubs.The only way now it to replaced the Tuner board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
SOURCE: Sony KDL-52V5100, HDMI 1 shows
I had this tv for almost a year, and I experienced this exact same problem about 3 or 4 times. The only thing you can do is turn the tv off and unplug it for a couple minutes. When you plug it back in it will work. This issue along with the intermittent sound issue on HDMI fed sources drove me crazy until I exchanged my tv for a KDL-52EX700. So glad to be done dealing with Sony customer support...because they're TERRIBLE. I had to email a VP at sony to get any results. The picture is beautiful on the V5100 for a lcd, but it's not worth dealing with the other issues...it's a flawed model. Hopefully your tv is still under warranty...you will have to call Sony and tell them your problem. They'll send a tech to come out, and he'll probably change out the motherboard..it won't fix anything. Then they'll probably send a tech out again to do the same thing when you keep calling...eventually they'll offer you an exchange. That's how it went for me...it was a 7 month nightmare.
