I found a "battery" website that had some suggestions that should be typical of any snap back case watch.
http://www.online-batteries.co.uk/whichb...specifically
they said that when you try to press the back on it must be flat (not
one edge down as I had been trying) Put the watch face down on a non
scratch surface and press with both thumbs evenly. If that doesn't work
a press will be needed. If you have a vice a couple of blocks of wood
to distribute the load on the front and back may work, otherwise take
it to a jeweler with the proper equipment.
The thumb routine
didn't work for me. I have a vice but figured many wouldn't so I tried
something else first. I put the watch face down on a piece of wood. I
found a small 2" long scrap of wood (3/4" x 1.5" approx) that spanned
the back. I centered the back (aligned properly) placed the block of
wood squarely and centered across the back and tapped the end of the
block with a hammer. First try didn't work, second one did. I used a
rubber mallet as the hammer but a regular hammer or other heavy object
would work. The trick, I think, is to get everything lined up and
square so the blow is centered and even.
Also, I'd suggest
cleaning the back and the groove in the case and be sure the rubber
gasket is properly positioned. This will give you the best chance of
retaining the waterproofing. And remember to check that the watch is
running before you do this. Some need to be reset (usually with a very
small screwdriver or pin) after replacing the battery. There should be
a small hole with some printing next to it. You may need a magnifying
glass to see/read it.
Hope this may help you;
