M-Audio Radium 49 keystation Hi, I reinstalled my PC, and after the whole installation ofVSTs in CubaseI tried to install Radium. Before the reinstallation ofXP, worked justfine, at the same time, it works on my laptop with USBsound-card, butin Cubase, if I try to select anything in device setup,still doesn´twork :o( Could it be because now I´m using differentchipset (P965) anddual-core CPU? There is only one driver on officialM-Audios support,have you been ever solved something like this? Ludweek www.ludweek.cz
First step is to download Midi Monitor http://www.snoize.com/MIDIMonitor/
just to make sure you're actually getting midi over USB into the computer. This is a great utility that I use all the time for troubleshooting midi data issues.
JA
vbmenu_register("postmenu_31136", true);
M-Audio Tech Support
"I asked our repairs department and they said the problem is either the
main board or the velocity board. You can order both boards from our
repairs department and return the one that is not needed. The main
board goes for $20 and the velocity board for $14. 626-610-2529, Mon -
Fri, 9am - 5pm Pacific Time."
I just found this in the M-Audio forums. I've just called the number and left a message at M-Audio requesting a callback. I'm really hoping that tech support will have a solution for whatever is causing this malfuntion. . . I'll post here again when the parts come.
u cannot install the driver for keystation49e with service pack 4,becoz sp4 will not support for external audio device,uninstall the sp4 and the ninstall the driver
