Universal MX-900 Remote Control Logo
s
stephen Posted on Jul 19, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why will the mx 900 not turn on even with new batteries
Level 3:
Top Expert:
  • Universal Master 76,851 Answers
  • Posted on Jul 20, 2014
Universal Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15000411
Points
237762
You should set up the remote control with the set-up codes to your device brand.
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site in "Mosaic" or "Magazine" view. It will make surf easier.
If remote control is found OK, and have infrared emission, set it up with your device by using the set-up codes.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
MX 900 says LOADER
http://www.manualslib.com/manual/484745/Universal-Remote-Control-Mx-900.html I hope this can help you get up and running Kerry. Thank you and leave feedback for I am a newbie! Universal Remote Control MX 900 Programming Manual
Genesis mx 900
Your remote needs to be cleaned internally.
Mx-900 wasn't switching channels. Tried new batteries but it is now reading loader. is there a way to get back to normal operation
Try removing the batteries, then short out the terminals in the remote. This should discharge any residual power in the components in the remote. Re insert the batteries and it should then work ok
Why won't MX 900 turn on even after putting in new batteries
The obvious question here is: are the batteries installed the correct way? Here is a web page to download the operator manual:
http://www.universalremote.com/pdf/MX-900OwnerManual.pdf
Also; are your batteries good? are they making good contact? Has the remote been damaged by leaking batteries? Inspect and test.
Do you have the original remote controls for the devices you are trying to control? If so... do they work? Remember... they will need batteries too!
Are there manual switches on the device you want to control? Do they work? Can you turn it on and off?
We are moving through a process to identify which items work, which are good and which are faulty.
Mx-900 remote buttons are stuck
retigh the springs contacts batteries with long pliers for better contacts, and clean it with c. cleaner very well.
2) open the rem.control and clean the keypads from dirty, corrosion, oxide, and bad contacts switch.
proof again,
If the problem persist you must go to the repair shop TV for fix it.ee the block d
God bless you
1helpful
Controller will only turn equipment on and off. Can't do anything else, ie: adjust volume, change channel, etc. Universal MX-900 Remote
Hello, Reset the remote control and use with the equipment . If it does adjust volume, change channel. then use have to get another one of different model
15helpful
4answers
Some buttons dont work
very easy fix. got to auto parts store and get permatex rear window defroster repair kit. next remove battery cover and batteries and pry open remote. once open take out the rubber sheet and clean the backside of connectors. open the kit and find the small bottle of conductive paint and brush a small dab on all the contact let dry a few minute and reassemble. Just like that better than new.
3answers
Where can I purchase a Lithium battery 046067 for an MX 3000?
Do you favorite search engine and type your model number and then batteries. What I got is www.buy.com
3answers
I can not get my MX-900 Universal Remote to connect to my compute
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
MX-900 Universal Remote Control
you might want to reprogram it with different codes. it's a classic problem.
Top Universal Televison & Video Experts
vince
Jennifer Rock
Jennifer Rock
Are you an Universal Televison and Video Expert? Answer questions, earn points and help others
