SOURCE: cannot get 1987 chevy van 20 to keep running... stalls out
Best do a fuel pressure test. Should have chg. fuel filter from the get go. The only other filter is on the end of the fuel pump in tank. Bad gas and dirty gas will plug up fuel filter, hense burn pump up.
SOURCE: 1992 Pace Arrow Motor Home 454 Chevy...not getting fuel to start
After you dump the fuel in the throttle body it will continue to run on its own or die as soon as it burns up all the fuel you dump in? Do you have access to (Noid lights)? Are both plugs attached to the distributor?
SOURCE: '87 dodge raider wont ilde.
My 88 raider did the same thing. As long as I had my foot on the gas pedal it would run but if I lifted off the gas it would die. It ended up being a vacuum line. I can't remember which one (possibly the AAP) but not sure. I did replace the AAP diaphragm and all of my vacuum lines.
SOURCE: 1996 GMC Sierra 1500 XC 4x4 5.7 Hard To Start
It is probably the fuel pump. If I remember the number correctly, this fuel system needs about 50 lbs to open a valve.
Until this valve opens, no fuel gets to the fuel nozzels.
SOURCE: engine will turn over but
try the emrgency cut off switch located in the trunk behind the driverside tailight.
